Ana içeriğe geç
Craig CMP801 Volume Controls Replacement
Neye ihtiyacın var
    1. Craig CMP801 Volume Controls Replacement, Back Cover: adım 1, 2 resimden 1. Craig CMP801 Volume Controls Replacement, Back Cover: adım 1, 2 resimden 2.
      • Locate the opening line between the cover and the device. Then locate the groove near the charging port.
      FixBot'a Sor
      Yorum Ekle
    2. Craig CMP801 Volume Controls Replacement: adım 2, 2 resimden 1. Craig CMP801 Volume Controls Replacement: adım 2, 2 resimden 2.
      • Use a metal spudger to separate the back cover from the front touch screen.
      • To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
      FixBot'a Sor
      Yorum Ekle
    3. Craig CMP801 Volume Controls Replacement: adım 3, 2 resimden 1. Craig CMP801 Volume Controls Replacement: adım 3, 2 resimden 2.
      • Continue to separate all of the clips around the device until the back cover comes off completely.
      FixBot'a Sor
      Yorum Ekle
    1. Craig CMP801 Volume Controls Replacement, Volume Controls: adım 4, 2 resimden 1. Craig CMP801 Volume Controls Replacement, Volume Controls: adım 4, 2 resimden 2.
      • After taking out the back cover, locate the black flap.
      • Open the black flap with the plastic opening tools.
      • Be careful not to break the flap when you open it.
      FixBot'a Sor
      Yorum Ekle
    2. Craig CMP801 Volume Controls Replacement: adım 5, 2 resimden 1. Craig CMP801 Volume Controls Replacement: adım 5, 2 resimden 2.
      Bu adımda kullanılan alet:
      $3.99
      • Once the tab is released, use the angled tweezers to take out the tab.
      • Be careful not to scratch the tab.
      FixBot'a Sor
      Yorum Ekle
    3. Craig CMP801 Volume Controls Replacement: adım 6, 2 resimden 1. Craig CMP801 Volume Controls Replacement: adım 6, 2 resimden 2.
      • Use the angled tweezers to pull the volume controls out and replace it with a new one.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 30
Her zaman: 608
