Ana içeriğe geç
Craig Electronics CMP773 Front and Rear Camera Replacement
Neye ihtiyacın var
  1. Craig Electronics CMP773 Front and Rear Camera Replacement, Front and Rear Camera: adım 1, 2 resimden 1. Craig Electronics CMP773 Front and Rear Camera Replacement, Front and Rear Camera: adım 1, 2 resimden 2.
    • Remove the two Phillips #00 screws from the bottom of the screen.
  2. Craig Electronics CMP773 Front and Rear Camera Replacement: adım 2, 2 resimden 1. Craig Electronics CMP773 Front and Rear Camera Replacement: adım 2, 2 resimden 2.
    • Insert a plastic opening tool underneath the screen.
    • Once the first tool is inserted, insert another opening tool along the same side of the tablet.
    • Pry them in opposite directions until the casing pops.
  3. Craig Electronics CMP773 Front and Rear Camera Replacement: adım 3, 2 resimden 1. Craig Electronics CMP773 Front and Rear Camera Replacement: adım 3, 2 resimden 2.
    • Move the opening tool along the edge of the tablet to continue popping the casing loose.
    • Once the casing is about half loose, remove it by hand.
  4. Craig Electronics CMP773 Front and Rear Camera Replacement: adım 4, 2 resimden 1. Craig Electronics CMP773 Front and Rear Camera Replacement: adım 4, 2 resimden 2.
    • Remove the tape from the power connection for the camera unit.
    • Unhinge the clamp on the camera power connection to expose the removable plug.
  5. Craig Electronics CMP773 Front and Rear Camera Replacement: adım 5, 1 resimden 1.
    • Gently remove the power ribbon from the connector.
  6. Craig Electronics CMP773 Front and Rear Camera Replacement: adım 6, 2 resimden 1. Craig Electronics CMP773 Front and Rear Camera Replacement: adım 6, 2 resimden 2.
    • Use the spudger to dislodge camera unit from the casing and remove it from the device.
Sonuç
Luke VanLangevelde
133 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S3-G4, Harley Fall 2019 IUPUI, Team S3-G4, Harley Fall 2019 üyesi
IUPUI-HARLEY-F19S3G4
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 85
