Ana içeriğe geç
Craig Electronics CMP773 Screen Replacement
Neye ihtiyacın var
  1. Craig Electronics CMP773 Screen Replacement, Screen: adım 1, 2 resimden 1. Craig Electronics CMP773 Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Remove two screws on the charging port side of the tablet using the Phillips #00 screwdriver.
  2. Craig Electronics CMP773 Screen Replacement: adım 2, 3 resimden 1. Craig Electronics CMP773 Screen Replacement: adım 2, 3 resimden 2. Craig Electronics CMP773 Screen Replacement: adım 2, 3 resimden 3.
    • Insert a plastic opening tool between the screen and the back of the tablet.
    • Insert another opening tool along the same side of the tablet and pry them in opposite directions until the casing pops.
    • Once roughly half of the case has been unlatched, it can be removed by hand.
  3. Craig Electronics CMP773 Screen Replacement: adım 3, 2 resimden 1. Craig Electronics CMP773 Screen Replacement: adım 3, 2 resimden 2.
    • Use the spudger to gently pry the camera from the casing.
  4. Craig Electronics CMP773 Screen Replacement: adım 4, 2 resimden 1. Craig Electronics CMP773 Screen Replacement: adım 4, 2 resimden 2.
    • Using your finger, remove the clamp that connects the screen power rib to the motherboard.
    • Using needle nose pliers, remove the ribbon.
  5. Craig Electronics CMP773 Screen Replacement: adım 5, 3 resimden 1. Craig Electronics CMP773 Screen Replacement: adım 5, 3 resimden 2. Craig Electronics CMP773 Screen Replacement: adım 5, 3 resimden 3.
    • Remove the second screen power connection from the motherboard using the same procedure as step 4.
  6. Craig Electronics CMP773 Screen Replacement: adım 6, 3 resimden 1. Craig Electronics CMP773 Screen Replacement: adım 6, 3 resimden 2. Craig Electronics CMP773 Screen Replacement: adım 6, 3 resimden 3.
    • Remove four screws from the motherboard using the Phillips #00 screwdriver.
  7. Craig Electronics CMP773 Screen Replacement: adım 7, 2 resimden 1. Craig Electronics CMP773 Screen Replacement: adım 7, 2 resimden 2.
    • Remove a single screw from the speaker using the Phillips #00 screwdriver.
    • Pry up on the locking tabs with the flat spudger.
  8. Craig Electronics CMP773 Screen Replacement: adım 8, 1 resimden 1.
    • Using needle nose pliers, remove the ground wire from the casing.
  9. Craig Electronics CMP773 Screen Replacement: adım 9, 1 resimden 1.
    • Using the plastic opening tool, remove the battery.
  10. Craig Electronics CMP773 Screen Replacement: adım 10, 2 resimden 1. Craig Electronics CMP773 Screen Replacement: adım 10, 2 resimden 2.
    • With all screws and components removed, gently remove the motherboard from the casing.
  11. Craig Electronics CMP773 Screen Replacement: adım 11, 3 resimden 1. Craig Electronics CMP773 Screen Replacement: adım 11, 3 resimden 2. Craig Electronics CMP773 Screen Replacement: adım 11, 3 resimden 3.
    • Insert the spudger in between the screen and case. Work your way around the outside of the screen.
  12. Craig Electronics CMP773 Screen Replacement: adım 12, 3 resimden 1. Craig Electronics CMP773 Screen Replacement: adım 12, 3 resimden 2. Craig Electronics CMP773 Screen Replacement: adım 12, 3 resimden 3.
    • Grasp the exposed screen corner and gently separate the screen from the housing.
Sonuç
Justin mersch
205 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S3-G4, Harley Fall 2019 IUPUI, Team S3-G4, Harley Fall 2019 üyesi
IUPUI-HARLEY-F19S3G4
4 Üyeler
3 adet Kılavuz yazıldı
Bir Yorum
What kind of battery does this device specifically use
Kris Miller - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 200
