Ana içeriğe geç
Craig Electronics CMP773 Volume/Power Control Button Replacement
Neye ihtiyacın var
  1. Craig Electronics CMP773 Volume/Power Control Button Replacement, Volume/Power Control Button: adım 1, 1 resimden 1.
    • Remove the two 3.2 mm PH000 screws near the charging port.
  2. Craig Electronics CMP773 Volume/Power Control Button Replacement: adım 2, 1 resimden 1.
    • Pry the back cover from the device along bottom edge.
  3. Craig Electronics CMP773 Volume/Power Control Button Replacement: adım 3, 1 resimden 1.
    • Continue prying along each edge of the device until back cover is free.
  4. Craig Electronics CMP773 Volume/Power Control Button Replacement: adım 4, 1 resimden 1.
    • On the back cover, find the location where the volume/power button is held.
    • The volume/power button is not held securely after back is removed so it may fall out of place while removing the back cover from the device.
  5. Craig Electronics CMP773 Volume/Power Control Button Replacement: adım 5, 2 resimden 1. Craig Electronics CMP773 Volume/Power Control Button Replacement: adım 5, 2 resimden 2.
    • Remove the old button and replace it with the new one.
Sonuç
Once the above steps have been successfully competed, power on the device. Enjoy your newly replaced volume/power control button.
Jessie L Morris
171 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G5, Harley Spring 2018 IUPUI, Team S1-G5, Harley Spring 2018 üyesi
IUPUI-HARLEY-S18S1G5
6 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 164
