Ana içeriğe geç
Craig Electronics CMP773 Volume/Power Control Button Replacement
Neye ihtiyacın var
  1. Craig Electronics CMP773 Volume/Power Control Button Replacement, Volume/Power Control Button: adım 1, 1 resimden 1.
    • Remove the two 3.2 mm PH000 screws near the charging port.
    FixBot'a Sor
    Yorum Ekle
  2. Craig Electronics CMP773 Volume/Power Control Button Replacement: adım 2, 1 resimden 1.
    • Pry the back cover from the device along bottom edge.
    FixBot'a Sor
    Yorum Ekle
  3. Craig Electronics CMP773 Volume/Power Control Button Replacement: adım 3, 1 resimden 1.
    • Continue prying along each edge of the device until back cover is free.
    FixBot'a Sor
    Yorum Ekle
  4. Craig Electronics CMP773 Volume/Power Control Button Replacement: adım 4, 1 resimden 1.
    • On the back cover, find the location where the volume/power button is held.
    • The volume/power button is not held securely after back is removed so it may fall out of place while removing the back cover from the device.
    FixBot'a Sor
    Yorum Ekle
  5. Craig Electronics CMP773 Volume/Power Control Button Replacement: adım 5, 2 resimden 1. Craig Electronics CMP773 Volume/Power Control Button Replacement: adım 5, 2 resimden 2.
    • Remove the old button and replace it with the new one.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Once the above steps have been successfully competed, power on the device. Enjoy your newly replaced volume/power control button.
Jessie L Morris
171 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G5, Harley Spring 2018 IUPUI, Team S1-G5, Harley Spring 2018 üyesi
IUPUI-HARLEY-S18S1G5
6 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 19
Her zaman: 442
