Giriş
In order for the Crayola Crayon Maker to melt crayon pieces and create new whole crayons, the light bulb needs to be in good working order. To replace a burned out bulb, all that is needed is a small Phillips screwdriver and a colorless 60-watt candelabra light bulb with a small base.
Aletler
Parçalar
Press the green arm away from the melting tray. Remove the melting tray.
Pop the metal arms out of the green pivot support.
Remove the 2 screws (.75cm in length) currently securing the metal melting tray with a Phillips #2 screwdriver.
The light bulb should now be revealed. Unscrew the burned out bulb and replace with a new bulb.
Bir başkası bu kılavuzu tamamladı.
