Ana içeriğe geç
Crayola Crayon Maker Light Bulb Removal and Replacement
Neye ihtiyacın var
  1. Crayola Crayon Maker Light Bulb Removal and Replacement, Take out the melting tray that is out of place.: adım 1, 3 resimden 1. Crayola Crayon Maker Light Bulb Removal and Replacement, Take out the melting tray that is out of place.: adım 1, 3 resimden 2. Crayola Crayon Maker Light Bulb Removal and Replacement, Take out the melting tray that is out of place.: adım 1, 3 resimden 3.
    • Press the green arm away from the melting tray. Remove the melting tray.
    • Pop the metal arms out of the green pivot support.
  2. Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the metal melting tray.: adım 2, 3 resimden 1. Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the metal melting tray.: adım 2, 3 resimden 2. Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the metal melting tray.: adım 2, 3 resimden 3.
    • Remove the 2 screws (.75cm in length) currently securing the metal melting tray with a Phillips #2 screwdriver.
  3. Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the light bulb: adım 3, 3 resimden 1. Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the light bulb: adım 3, 3 resimden 2. Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the light bulb: adım 3, 3 resimden 3.
    • The light bulb should now be revealed. Unscrew the burned out bulb and replace with a new bulb.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Heidi Clarke
222 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 19
Her zaman: 6,603
