Ana içeriğe geç
Creality CR 10s Pro V2 Nozzle Replacement
Neye ihtiyacın var
  1. Creality CR 10s Pro V2 Nozzle Replacement, Nozzle: adım 1, 3 resimden 1. Creality CR 10s Pro V2 Nozzle Replacement, Nozzle: adım 1, 3 resimden 2. Creality CR 10s Pro V2 Nozzle Replacement, Nozzle: adım 1, 3 resimden 3.
    • Using a 2 mm hex key, remove the two screws that secure the fan cover.
    • While removing the screws, hold the fan cover with one hand to prevent it from falling once it's detached.
    • Position the fan cover in a way that doesn't damage the external wires.
    • Remove the silicone sock from the extruder nozzle.
  2. Creality CR 10s Pro V2 Nozzle Replacement: adım 2, 3 resimden 1. Creality CR 10s Pro V2 Nozzle Replacement: adım 2, 3 resimden 2. Creality CR 10s Pro V2 Nozzle Replacement: adım 2, 3 resimden 3.
    • Go to your LCD Screen >Temp > Manual >Nozzle Pre-Heat.
    • Pre-heat the nozzle to 230C.
    • The heat will loosen the nozzle so it can be unscrewed.
  3. Creality CR 10s Pro V2 Nozzle Replacement: adım 3, 2 resimden 1. Creality CR 10s Pro V2 Nozzle Replacement: adım 3, 2 resimden 2.
    • The equipment is hot! Be careful when working with the metals parts so you don't burn yourself.
    • Once the nozzle is sufficiently heated, use an adjustable crescent wrench to firmly hold the heater block.
    • With the other hand, use the tappit wrench to unscrew the nozzle.
    • Allow the printer to cool down.
  4. Creality CR 10s Pro V2 Nozzle Replacement: adım 4, 2 resimden 1. Creality CR 10s Pro V2 Nozzle Replacement: adım 4, 2 resimden 2.
    • Hot Equipment!
    • Once the heater block is cooled down, slightly thread the new nozzle onto the heater block.
    • Manually set the nozzle pre-heat to 230C and finish threading the new nozzle.
    • Be careful to not over-tighten the nozzle. Overtightening can also damage the heater block or the nozzle.
  5. Creality CR 10s Pro V2 Nozzle Replacement: adım 5, 1 resimden 1.
    • Using the 2 mm hex key, replace the fan cover to the extruder.
    • It is important to relevel the print bed after changing the nozzle. Such change can affect the distance between the nozzle and the print bed.
Sonuç
To ensure the nozzle replacement has been followed correctly, calibrate your 3D printer.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 19
Son 30 gün: 52
Her zaman: 404
