Ana içeriğe geç
Creality Ender 3 Pro Hotend Nozzle Replacement
Neye ihtiyacın var
  1. Creality Ender 3 Pro Hotend Nozzle Replacement, Hotend Nozzle: adım 1, 3 resimden 1. Creality Ender 3 Pro Hotend Nozzle Replacement, Hotend Nozzle: adım 1, 3 resimden 2. Creality Ender 3 Pro Hotend Nozzle Replacement, Hotend Nozzle: adım 1, 3 resimden 3.
    • Press the knob to enter the Ender 3 Pro menu.
    • Turn the knob to navigate to the temperature menu.
    • Click on the nozzle setting found in the temperature menu.
    • Turn the knob to set the nozzle to 200 C.
  2. Creality Ender 3 Pro Hotend Nozzle Replacement: adım 2, 1 resimden 1.
    • Wait for the nozzle to heat up.
    • The nozzle will be at 200 C and should be handled with care to avoid burning yourself.
  3. Creality Ender 3 Pro Hotend Nozzle Replacement: adım 3, 3 resimden 1. Creality Ender 3 Pro Hotend Nozzle Replacement: adım 3, 3 resimden 2. Creality Ender 3 Pro Hotend Nozzle Replacement: adım 3, 3 resimden 3.
    • Depress the extruder spring using the handle.
    • Pull the filament from the extruder, while keeping constant pressure on the extruder spring.
  4. Creality Ender 3 Pro Hotend Nozzle Replacement: adım 4, 3 resimden 1. Creality Ender 3 Pro Hotend Nozzle Replacement: adım 4, 3 resimden 2. Creality Ender 3 Pro Hotend Nozzle Replacement: adım 4, 3 resimden 3.
    • Unscrew the two screws holding the fan shroud in place using the proper Allen key.
  5. Creality Ender 3 Pro Hotend Nozzle Replacement: adım 5, 2 resimden 1. Creality Ender 3 Pro Hotend Nozzle Replacement: adım 5, 2 resimden 2.
    • The hot end is still at 200 C, so be careful not to burn yourself!
    • Remove the silicon sock covering the hot end and nozzle.
  6. Creality Ender 3 Pro Hotend Nozzle Replacement: adım 6, 2 resimden 1. Creality Ender 3 Pro Hotend Nozzle Replacement: adım 6, 2 resimden 2.
    • Grab the hotend at the specified points using an adjustable wrench.
    • Be careful to avoid clamping the wires, ensuring the adjustable wrench only grabs the metal.
  7. Creality Ender 3 Pro Hotend Nozzle Replacement: adım 7, 2 resimden 1. Creality Ender 3 Pro Hotend Nozzle Replacement: adım 7, 2 resimden 2.
    • Remove the nozzle with a 7mm socket wrench.
  8. Creality Ender 3 Pro Hotend Nozzle Replacement: adım 8, 3 resimden 1. Creality Ender 3 Pro Hotend Nozzle Replacement: adım 8, 3 resimden 2. Creality Ender 3 Pro Hotend Nozzle Replacement: adım 8, 3 resimden 3.
    • Place the new nozzle within the 7mm socket wrench.
    • Grab the hotend using the adjustable wrench as seen in step 7.
    • Screw in the new nozzle again using the 7mm socket wrench.
    • Ensure the nozzle is hand tight as to not damage the hotend.
  9. Creality Ender 3 Pro Hotend Nozzle Replacement: adım 9, 2 resimden 1. Creality Ender 3 Pro Hotend Nozzle Replacement: adım 9, 2 resimden 2.
    • Reattach the fan shroud by screwing in the two screws.
    • Place the silicon sock back on the hot end, avoiding contact with the metal.
  10. Creality Ender 3 Pro Hotend Nozzle Replacement: adım 10, 3 resimden 1. Creality Ender 3 Pro Hotend Nozzle Replacement: adım 10, 3 resimden 2. Creality Ender 3 Pro Hotend Nozzle Replacement: adım 10, 3 resimden 3.
    • Navigate back to the temperature menu.
    • Set the nozzle temperature to 0 C, allowing it to cool down fully.
Bitiş Çizgisi
Vincent Lowe
181 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 36
Her zaman: 436
