Giriş
The hot end of a 3D printer is the most common cause for failed prints and general problems with a printer. This is due to the nature of the hotend, as it is the most used and strained part of a printer. Replacing the hotend is, fortunately, not too difficult. This guide details how to replace the hotend of an Ender 3 3D printer. As a warning, this process may involve working with a heated element that is around 240 degrees Celsius or 464 degrees Fahrenheit, extreme caution is advised.
Neye ihtiyacın var
Press the knob to enter the marlin LCD menu and turn it to navigate between the options.
Navigate to Temperature > Nozzle.
Adjust the nozzle temperature by turning the knob and confirm by pressing it.
Wait until the current temperature (bottom) matches the target temperature (top).
Press down on the extruder lever arm and pull out the loaded filament.
Remove the two screws from the fan housing using the 2 mm hex key.
Pull the housing away from the hotend assembly and set the screws aside.
To reassemble your device, follow these instructions in reverse order. Make sure that if you kept the original tubing, that the tubing inserted into the hotend is pushed all the way down.
4 farklı kişi bu kılavuzu tamamladı.
