Ana içeriğe geç
Creative Nomad II Lock/Unlock Switch Replacement
Neye ihtiyacın var
  1. Creative Nomad II Lock/Unlock Switch Replacement, Battery: adım 1, 1 resimden 1.
    • Using your thumb, slide down and remove the battery cover.
  2. Creative Nomad II Lock/Unlock Switch Replacement: adım 2, 1 resimden 1.
    • Using your index finger, remove the old AA battery.
    • Install the new AA battery.
  3. Creative Nomad II Lock/Unlock Switch Replacement, Smart Media Card: adım 3, 1 resimden 1.
    • Slide down the eject button.
    • Pull out the old SmartMedia Card.
    • Insert the new SmartMedia Card.
    • The notched corner of the SmartMedia card should go in the top left corner.
  4. Creative Nomad II Lock/Unlock Switch Replacement, Back Cover: adım 4, 1 resimden 1.
    • Using a Phillips #00 Screwdriver, remove the two 7.5mm screws from the sides of the back cover.
  5. Creative Nomad II Lock/Unlock Switch Replacement: adım 5, 1 resimden 1.
    • Lift the back cover off of the NOMAD II.
    • Remove the rubber USB port cover, the connected buttons along the left edge, and the plastic lock/unlock button on the upper right edge of the device.
  6. Creative Nomad II Lock/Unlock Switch Replacement, Battery Compartment: adım 6, 1 resimden 1.
    • Using a Phillips #00 Screwdriver, remove the two 5.5mm screws from the sides of the battery compartment.
  7. Creative Nomad II Lock/Unlock Switch Replacement: adım 7, 1 resimden 1.
    • Carefully remove the battery compartment.
  8. Creative Nomad II Lock/Unlock Switch Replacement, Circuit Boards: adım 8, 1 resimden 1.
    • Using a Phillips #00 Screwdriver, remove the two 5.5mm screws on the left and right edges of the circuit board.
  9. Creative Nomad II Lock/Unlock Switch Replacement: adım 9, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using a pair of tweezers, carefully pry the metal loop on the left side of the battery compartment away from the case.
  10. Creative Nomad II Lock/Unlock Switch Replacement: adım 10, 1 resimden 1.
    • Pull the circuit boards out of the back cover.
    • During reinstallation, firmly press the top of the circuit boards into the cover until you hear a click.
  11. Creative Nomad II Lock/Unlock Switch Replacement: adım 11, 1 resimden 1.
    • Gently pry the circuit boards apart.
    • This must be done with the USB port facing up, as shown.
  12. Creative Nomad II Lock/Unlock Switch Replacement, Lock/Unlock Switch: adım 12, 1 resimden 1.
    • Desolder the seven solder joints which hold the lock switch in place.
    • Install the new lock/unlock switch.
Sonuç
Craig Fischer
21 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-2, Regan Winter 2012 Cal Poly, Team 9-2, Regan Winter 2012 üyesi
CPSU-REGAN-W12S9G2
5 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 1,913
