Ana içeriğe geç
Creative Nomad Jukebox Zen Display Screen Replacement
Neye ihtiyacın var
  1. Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: adım 1, 3 resimden 1. Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: adım 1, 3 resimden 2. Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: adım 1, 3 resimden 3.
    • Use a J0 screwdriver to remove the eight 3.5mm screws.
  2. Creative Nomad Jukebox Zen Display Screen Replacement: adım 2, 3 resimden 1. Creative Nomad Jukebox Zen Display Screen Replacement: adım 2, 3 resimden 2. Creative Nomad Jukebox Zen Display Screen Replacement: adım 2, 3 resimden 3.
    • Use the plastic opening tool to open the top cover by carefully prying at each corner.
  3. Creative Nomad Jukebox Zen Display Screen Replacement, Screen Cover: adım 3, 1 resimden 1.
    • Once the front face is removed, remove the three 6.8mm J0 screws from the metal cover and remove it.
  4. Creative Nomad Jukebox Zen Display Screen Replacement, Display Screen: adım 4, 1 resimden 1.
    • Using the plastic opening tool to pop the metal tab holding the battery in place.
    • By breaking the sticker, it could void your warranty
  5. Creative Nomad Jukebox Zen Display Screen Replacement: adım 5, 2 resimden 1. Creative Nomad Jukebox Zen Display Screen Replacement: adım 5, 2 resimden 2.
    • Use the spudger tool to unclip the screens wiring pigtail clipped into the motherboard.
  6. Creative Nomad Jukebox Zen Display Screen Replacement: adım 6, 2 resimden 1. Creative Nomad Jukebox Zen Display Screen Replacement: adım 6, 2 resimden 2.
    • Use soldering iron to melt the solder used to hold the display screen to the motherboard.
    • Using soldering gun with care as it becomes extremely hot and can cause burns.
  7. Creative Nomad Jukebox Zen Display Screen Replacement: adım 7, 1 resimden 1.
    • Using the spudger tool, gently pry up the corners of the display screen to remove it.
Sonuç
Austin Shaw
101 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S4-G5, Baechle Spring 2017 IUPUI, Team S4-G5, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S4G5
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 19
Her zaman: 607
