Ana içeriğe geç
Creative Zen V Plus Logic Board Replacement
Neye ihtiyacın var
  1. Creative Zen V Plus Logic Board Replacement, Prerequisite Only: adım 1, 1 resimden 1.
    • Find the grooves around the buttons on the front and carefully remove the panel. This can be done without the use of any tools.
  2. Creative Zen V Plus Logic Board Replacement: adım 2, 1 resimden 1.
    • Using a plastic opening tool, place the skinny flat end between the groove running along side of the device.
    • Using a twisting motion, detach the control panel from the device
  3. Creative Zen V Plus Logic Board Replacement: adım 3, 1 resimden 1.
    • Find the groove around the outside of the green section. Use an ESD safe spudger to slowly lift the plastic panel up.
  4. Creative Zen V Plus Logic Board Replacement: adım 4, 2 resimden 1. Creative Zen V Plus Logic Board Replacement: adım 4, 2 resimden 2.
    • After removing the green section, find the groove around the display. Insert a ESD safe spudger and carefully lift the display.
  5. Creative Zen V Plus Logic Board Replacement: adım 5, 1 resimden 1.
    • The display can lift up the display but be sure not to damage any of the cables connecting it to the mother board.
    • Remove the screw located under the display using the 00 Phillips head screwdriver.
  6. Creative Zen V Plus Logic Board Replacement: adım 6, 3 resimden 1. Creative Zen V Plus Logic Board Replacement: adım 6, 3 resimden 2. Creative Zen V Plus Logic Board Replacement: adım 6, 3 resimden 3.
    • Pull up on the motherboard and display. It is glued to the base so it will require a little force. Be careful though, as the board is fragile.
  7. Creative Zen V Plus Logic Board Replacement, Logic Board: adım 7, 1 resimden 1.
    • Unplug the logic board from the battery. Replace the logic board with your new logic board and reassemble your device.
Sonuç
Joel Ng
239 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-5, Baechle Fall 2016 IUPUI, Team 2-5, Baechle Fall 2016 üyesi
IUPUI-BAECHLE-F16S2G5
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 457
