Ana içeriğe geç
Creative Zen Vision M Screen Replacement
Neye ihtiyacın var
    1. Creative Zen Vision M Screen Replacement, Opening the top: adım 1, 2 resimden 1. Creative Zen Vision M Screen Replacement, Opening the top: adım 1, 2 resimden 2.
      • Pop off the top plastic on the device with a flat tool like a flathead screwdriver.
      • Unscrew and remove the two exposed Phillips head screws.
      FixBot'a Sor
      Yorum Ekle
    2. Creative Zen Vision M Screen Replacement, Opening the device: adım 2, 2 resimden 1. Creative Zen Vision M Screen Replacement, Opening the device: adım 2, 2 resimden 2.
      • Work your way around the recess of the device with a flat tool like a flathead screwdriver.
      • Don't try attempt to open it from the recess between the buttons and the device.
      FixBot'a Sor
      Yorum Ekle
    3. Creative Zen Vision M Screen Replacement, Disconnecting the battery: adım 3, 3 resimden 1. Creative Zen Vision M Screen Replacement, Disconnecting the battery: adım 3, 3 resimden 2. Creative Zen Vision M Screen Replacement, Disconnecting the battery: adım 3, 3 resimden 3.
      • Disconnect the wire from the bottom device.
      • Handle with care as the wires tend to disconnect easily.
      FixBot'a Sor
      Yorum Ekle
    4. Creative Zen Vision M Screen Replacement, Disconnecting the hard drive: adım 4, 1 resimden 1.
      • In the top right corner, pull the black foam square off to separate the hard drive from the screen.
      • Handle with care as the hard drive also comes off easily.
      FixBot'a Sor
      Yorum Ekle
    5. Creative Zen Vision M Screen Replacement, Unscrewing from the mother board: adım 5, 1 resimden 1.
      • Unscrew the seven screws placed around the mother board.
      • You will need a one millimeter Phillips head screwdriver.
      • The screws are small, so keep them safely.
      FixBot'a Sor
      Yorum Ekle
    6. Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: adım 6, 3 resimden 1. Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: adım 6, 3 resimden 2. Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: adım 6, 3 resimden 3.
      • Flip your device upside down so that the motherboard will loosen.
      • Detach the connector from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    7. Creative Zen Vision M Screen Replacement, Removing the screen: adım 7, 2 resimden 1. Creative Zen Vision M Screen Replacement, Removing the screen: adım 7, 2 resimden 2.
      • Tilt the screen diagonally. Separate the screen and motherboard from the device frame.
      • Lift the light gray flap to detach the screen from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    8. Creative Zen Vision M Screen Replacement, Seperating the digital display: adım 8, 2 resimden 1. Creative Zen Vision M Screen Replacement, Seperating the digital display: adım 8, 2 resimden 2.
      • Separate the clear screen frame from the digital display.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kirstie G
488 İtibar
4 adet Kılavuz yazıldı
Ekip
Texas Tech, Team 12-1, Bennett Fall 2016 Texas Tech, Team 12-1, Bennett Fall 2016 üyesi
TTU-BENNETT-F16S12G1
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 36
Her zaman: 1,983
