Ana içeriğe geç
Creative Zen Vision W Battery Replacement
Neye ihtiyacın var
  1. Creative Zen Vision W Battery Replacement, Battery Removal: adım 1, 3 resimden 1. Creative Zen Vision W Battery Replacement, Battery Removal: adım 1, 3 resimden 2. Creative Zen Vision W Battery Replacement, Battery Removal: adım 1, 3 resimden 3.
    • Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
    FixBot'a Sor
    Yorum Ekle
  2. Creative Zen Vision W Battery Replacement, Battery: adım 2, 2 resimden 1. Creative Zen Vision W Battery Replacement, Battery: adım 2, 2 resimden 2.
    • Remove the three 4 mm exposed screws using a Phillips #0 screwdriver.
    • Peel off the the sticker that says "Creative Warranty Void if broken" and remove the 4 mm screw beneath with a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Creative Zen Vision W Battery Replacement: adım 3, 3 resimden 1. Creative Zen Vision W Battery Replacement: adım 3, 3 resimden 2. Creative Zen Vision W Battery Replacement: adım 3, 3 resimden 3.
    • Remove the battery from the casing by bending the sides. The battery should pop out. Be careful not to snap the case.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Follow these instructions in reverse order to reassemble your device.
2 farklı kişi bu kılavuzu tamamladı.
Tim Wilson
143 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-2, Regan Spring 2013 Cal Poly, Team 17-2, Regan Spring 2013 üyesi
CPSU-REGAN-S13S17G2
4 Üyeler
16 adet Kılavuz yazıldı
3Kılavuz Yorumları
Where can I buy the battery, does not seem to be available on ebay or amazon
Mafaz - Yanıt Paylaş
where can i buy this exact battery. Can't find it with 6 tabs, only 4.
Bernie - Yanıt Paylaş
Can’t find a replacement battery nor the amp hours or wattage etc.. I’d even be ok with building a new housing to hold a larger battery, but I need the specs… I’ve got a vaccum table and can make a larger case to hold the battery.. But dang I’ve got to know how much power to provide to the unit and at how fast!
Matt Wyckoff - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 63
Her zaman: 7,189
