Giriş
Use this guide to replace a dead battery.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
Remove the three exposed screws (4 mm) using a #0 Phillips.
Peel off the the sticker that says "Creative Warranty Void if broken" and remove the screw (4 mm) beneath with a #0 Phillips.
2 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Can’t find a replacement battery nor the amp hours or wattage etc.. I’d even be ok with building a new housing to hold a larger battery, but I need the specs… I’ve got a vaccum table and can make a larger case to hold the battery.. But dang I’ve got to know how much power to provide to the unit and at how fast!
