Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
Remove the three 4 mm exposed screws using a Phillips #0 screwdriver.
Peel off the the sticker that says "Creative Warranty Void if broken" and remove the 4 mm screw beneath with a Phillips #0 screwdriver.
Remove the battery from the casing by bending the sides. The battery should pop out. Be careful not to snap the case.
2 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Can’t find a replacement battery nor the amp hours or wattage etc.. I’d even be ok with building a new housing to hold a larger battery, but I need the specs… I’ve got a vaccum table and can make a larger case to hold the battery.. But dang I’ve got to know how much power to provide to the unit and at how fast!
