Ana içeriğe geç
Giriş
This guide will show you how to remove the front cover of your device. Use this guide to gain access to the button pad and LCD screen.
Parçalar
Hiçbir parça belirtilmedi.
  1. Creative Zen Vision W Front Cover Replacement, Front Cover: step 1, image 1 of 1
    • Remove 2 screws (2.5 mm) on the top of the device using Phillips #0.
  2. Creative Zen Vision W Front Cover Replacement: step 2, image 1 of 1
    • Remove 2 screws (2.5 mm) on the bottom of the device using a Phillips #0.
  3. Creative Zen Vision W Front Cover Replacement: step 3, image 1 of 3 Creative Zen Vision W Front Cover Replacement: step 3, image 2 of 3 Creative Zen Vision W Front Cover Replacement: step 3, image 3 of 3
    • Use a spudger to get between the cover and the screen. Carefully lift the cover off of the screen without putting too much pressure on the screen.
    • When the cover has been lifted off the screen, use your hands to remove it from the device.
    • The button pad may fall off when the cover is removed.
Sonuç
Gabriele Pregadio
1 İtibar
2 adet Kılavuz yazıldı
Takım
Cal Poly, Team 17-2, Regan Spring 2013 Cal Poly, Team 17-2, Regan Spring 2013 üyesi
CPSU-REGAN-S13S17G2
4 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Fantastic but does anyone know where I can get this part?
VegetaFlex4Fitness - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 336
