Giriş
This guide will show you how to remove and install the keypad for your device. Use this guide if your buttons stop working because the keypad is broken.
Parçalar
Hiçbir parça belirtilmedi.
Use a spudger to get between the cover and the screen. Carefully lift the cover off of the screen without putting too much pressure on the screen.
When the cover has been lifted off the screen, use your hands to remove it from the device.
The button pad may fall off when the cover is removed.
Use a spudger to separate the metal tabs that hold the screen in place on the right side.
