Giriş
This step-by-step guide will show you how to remove a broken keypad and install a new one on your device when the buttons stop working. This guide is for you if you are looking to fix the keyboard to your Creative Zen Vision device.
The buttons are used to turn the device on and off, as well as allowing you to switch shows and use controls. When the buttons do not work, the device will not function properly.
Before beginning, make sure to unplug your device from any external power sources to ensure safety.
Neye ihtiyacın var
Remove the two screws (2.5 mm) on the top and bottom of the device using a Phillips #0 screwdriver.
Use a spudger to separate the metal tabs that hold the screen in place on the right side.
