Ana içeriğe geç
Creative Zen Vision W LCD Screen Replacement
Neye ihtiyacın var
  1. Creative Zen Vision W LCD Screen Replacement, Front Cover: adım 1, 2 resimden 1. Creative Zen Vision W LCD Screen Replacement, Front Cover: adım 1, 2 resimden 2.
    • Remove the two screws (2.5 mm) on the top and bottom of the device using a Phillips #0 screwdriver.
  2. Creative Zen Vision W LCD Screen Replacement: adım 2, 3 resimden 1. Creative Zen Vision W LCD Screen Replacement: adım 2, 3 resimden 2. Creative Zen Vision W LCD Screen Replacement: adım 2, 3 resimden 3.
    • Run the spudger along the cover and pry.
    • Do this gently to preserve the screen
    • The button pad may fall off when the cover is removed.
  3. Creative Zen Vision W LCD Screen Replacement, LCD Screen: adım 3, 3 resimden 1. Creative Zen Vision W LCD Screen Replacement, LCD Screen: adım 3, 3 resimden 2. Creative Zen Vision W LCD Screen Replacement, LCD Screen: adım 3, 3 resimden 3.
    • Use a spudger to separate the metal tabs that hold the screen in place on the right side.
    • The screen is still attached underneath with two ribbon cables. Lift it very carefully.
  4. Creative Zen Vision W LCD Screen Replacement: adım 4, 1 resimden 1.
    • Put the screen face down so you can see where the ribbon cables are attached.
    • Remove the red sticker that covers the ribbon cable connections.
  5. Creative Zen Vision W LCD Screen Replacement: adım 5, 1 resimden 1.
    • Use a plastic opening tool to get underneath the black flap on the larger ribbon cable connection and lift it.
  6. Creative Zen Vision W LCD Screen Replacement: adım 6, 3 resimden 1. Creative Zen Vision W LCD Screen Replacement: adım 6, 3 resimden 2. Creative Zen Vision W LCD Screen Replacement: adım 6, 3 resimden 3.
    • Use a spudger to slide the two small gray tabs away from the ribbon cable connection.
    • Remove the screen from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tim Wilson
143 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-2, Regan Spring 2013 Cal Poly, Team 17-2, Regan Spring 2013 üyesi
CPSU-REGAN-S13S17G2
4 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Where can I get the screen
Home Watch - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 1,392
