Ana içeriğe geç
Creative Zen X-Fi LCD Screen Replacement
Neye ihtiyacın var
  1. Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: adım 1, 3 resimden 1. Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: adım 1, 3 resimden 2. Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: adım 1, 3 resimden 3.
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
    FixBot'a Sor
    Yorum Ekle
  2. Creative Zen X-Fi LCD Screen Replacement, Rubber Button Cover: adım 2, 1 resimden 1.
    • The black rubber button pad can be removed by simply picking it up.
    FixBot'a Sor
    Yorum Ekle
  3. Creative Zen X-Fi LCD Screen Replacement, Button Input Chip Part 1: adım 3, 1 resimden 1.
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
    FixBot'a Sor
    Yorum Ekle
  4. Creative Zen X-Fi LCD Screen Replacement, Button Input Chip: adım 4, 1 resimden 1.
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
    FixBot'a Sor
    Yorum Ekle
  5. Creative Zen X-Fi LCD Screen Replacement, Access Midsection Plate: adım 5, 1 resimden 1.
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
    FixBot'a Sor
    Yorum Ekle
  6. Creative Zen X-Fi LCD Screen Replacement, Unscrew below Button Chip: adım 6, 1 resimden 1.
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
    FixBot'a Sor
    Yorum Ekle
  7. Creative Zen X-Fi LCD Screen Replacement, Unscrew below LCD Screen: adım 7, 1 resimden 1.
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
    FixBot'a Sor
    Yorum Ekle
  8. Creative Zen X-Fi LCD Screen Replacement, Pull the Motherboard Out: adım 8, 2 resimden 1. Creative Zen X-Fi LCD Screen Replacement, Pull the Motherboard Out: adım 8, 2 resimden 2.
    • Lift the right edge of the motherboard off the back case.
    • Using two fingers to grip the edge of the board, slide the motherboard out of the case to the right.
    FixBot'a Sor
    Yorum Ekle
  9. Creative Zen X-Fi LCD Screen Replacement, Disconnect the LCD Screen: adım 9, 2 resimden 1. Creative Zen X-Fi LCD Screen Replacement, Disconnect the LCD Screen: adım 9, 2 resimden 2.
    • Use two fingers to peel back the edge of the ribbon connector that is glued to the bottom of the LCD screen.
    FixBot'a Sor
    Yorum Ekle
  10. Creative Zen X-Fi LCD Screen Replacement, Unlatch the LCD Screen: adım 10, 1 resimden 1.
    • Using a plastic opening tool, unlock the ribbon connector by unlatching the black lever that pins it on the motherboard.
    • Once the black lever arm is open, pull the ribbon connector out to disconnect the LCD screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Westley Courchene
3.410 İtibar
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 17
Son 30 gün: 65
Her zaman: 2,053
