Ana içeriğe geç
Creative Ziio 7" Battery Replacement
Neye ihtiyacın var
  1. Creative Ziio 7" Battery Replacement, Back Panel: adım 1, 3 resimden 1. Creative Ziio 7" Battery Replacement, Back Panel: adım 1, 3 resimden 2. Creative Ziio 7" Battery Replacement, Back Panel: adım 1, 3 resimden 3.
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
  2. Creative Ziio 7" Battery Replacement, Battery: adım 2, 3 resimden 1. Creative Ziio 7" Battery Replacement, Battery: adım 2, 3 resimden 2. Creative Ziio 7" Battery Replacement, Battery: adım 2, 3 resimden 3.
    • Remove the copper plate covering the motherboard by desoldering the ten solder points so that the copper plate is free.
    • The last point is hidden by the soldering iron.
    • Remove the copper plate once all the solder points are undone.
  3. Creative Ziio 7" Battery Replacement: adım 3, 2 resimden 1. Creative Ziio 7" Battery Replacement: adım 3, 2 resimden 2.
    • Remove adhesive tape covering the three wires connected to the motherboard.
    • Desolder the solder points connecting the wires to the mother board.
  4. Creative Ziio 7" Battery Replacement: adım 4, 2 resimden 1. Creative Ziio 7" Battery Replacement: adım 4, 2 resimden 2.
    • With a spudger, pry the battery from the back of the LCD screen.
    • The battery is attached with double sided foam tape. When prying, the tape will probably not come apart easy. This will result in the tape tearing and leaving residue.
  5. Creative Ziio 7" Battery Replacement: adım 5, 1 resimden 1.
    • Remove old battery and dispose of it responsibly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bryce Simmons
150 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-10, Maness Spring 2013 Cal Poly, Team 14-10, Maness Spring 2013 üyesi
CPSU-MANESS-S13S14G10
4 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 16
Her zaman: 967
