Ana içeriğe geç
Creative Ziio 7" Camera Replacement
Neye ihtiyacın var
  1. Creative Ziio 7" Camera Replacement, Back Panel: adım 1, 3 resimden 1. Creative Ziio 7" Camera Replacement, Back Panel: adım 1, 3 resimden 2. Creative Ziio 7" Camera Replacement, Back Panel: adım 1, 3 resimden 3.
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
    FixBot'a Sor
    Yorum Ekle
  2. Creative Ziio 7" Camera Replacement, Camera: adım 2, 3 resimden 1. Creative Ziio 7" Camera Replacement, Camera: adım 2, 3 resimden 2. Creative Ziio 7" Camera Replacement, Camera: adım 2, 3 resimden 3.
    • Unscrew the four 3mm Phillips #00 screws found in each corner of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  3. Creative Ziio 7" Camera Replacement: adım 3, 3 resimden 1. Creative Ziio 7" Camera Replacement: adım 3, 3 resimden 2. Creative Ziio 7" Camera Replacement: adım 3, 3 resimden 3.
    • Unplug the ribbon cable near the edge of the motherboard in the bottom right of the device.
    FixBot'a Sor
    Yorum Ekle
  4. Creative Ziio 7" Camera Replacement: adım 4, 2 resimden 1. Creative Ziio 7" Camera Replacement: adım 4, 2 resimden 2.
    • Lift up the motherboard.
    • A mesh-like strip on the right side will be connected to the bottom of the motherboard.
    • Remove the tape on top of the strip. Use tweezers or pliers to pull on the strip and unplug it.
    FixBot'a Sor
    Yorum Ekle
  5. Creative Ziio 7" Camera Replacement: adım 5, 2 resimden 1. Creative Ziio 7" Camera Replacement: adım 5, 2 resimden 2.
    • Lift up the motherboard and locate the ribbon cable (burnt orange-colored strip) centered on top of the motherboard.
    • The ribbon cable with the attached camera is plugged into the motherboard.
    • Unplug the ribbon cable using your fingers to pull up on the flap.
    FixBot'a Sor
    Yorum Ekle
  6. Creative Ziio 7" Camera Replacement: adım 6, 2 resimden 1. Creative Ziio 7" Camera Replacement: adım 6, 2 resimden 2.
    • Use a spudger to pry the camera away from the rubber camera mount.
    • Do not remove the entire rubber camera mount. Only remove the camera attached with adhesive.
    • Remove the broken camera and use electronic-friendly adhesive to attach a new camera.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ekip
Cal Poly, Team 14-10, Maness Spring 2013 Cal Poly, Team 14-10, Maness Spring 2013 üyesi
CPSU-MANESS-S13S14G10
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 30
Her zaman: 737
