Ana içeriğe geç
Creative Ziio 7" LCD Screen Replacement
Neye ihtiyacın var
  1. Creative Ziio 7" LCD Screen Replacement, Back Panel: adım 1, 3 resimden 1. Creative Ziio 7" LCD Screen Replacement, Back Panel: adım 1, 3 resimden 2. Creative Ziio 7" LCD Screen Replacement, Back Panel: adım 1, 3 resimden 3.
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
    FixBot'a Sor
    Yorum Ekle
  2. Creative Ziio 7" LCD Screen Replacement, LCD Screen: adım 2, 1 resimden 1.
    • Remove the four 3mm Philips #00 screws around the large silver battery.
    FixBot'a Sor
    Yorum Ekle
  3. Creative Ziio 7" LCD Screen Replacement: adım 3, 1 resimden 1.
    • Remove the four 4mm Philips #00 screws on the edges of the circuit board.
    FixBot'a Sor
    Yorum Ekle
  4. Creative Ziio 7" LCD Screen Replacement: adım 4, 3 resimden 1. Creative Ziio 7" LCD Screen Replacement: adım 4, 3 resimden 2. Creative Ziio 7" LCD Screen Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the ribbon cable from the exposed side of circuit board near the headphone jack.
    • Carefully lift up the circuit board on the detached side.
    • There is another ribbon cable attached to the underside of the circuit board.
    • Disconnect the second ribbon cable by pulling the end of the ribbon from its housing on the circuit board with tweezers.
    • The circuit board is extremely delicate. Move carefully and don't rush on this step!
    FixBot'a Sor
    Yorum Ekle
  5. Creative Ziio 7" LCD Screen Replacement: adım 5, 1 resimden 1.
    • On the opposite end of the device: Remove the ribbon cable in between the speakers at the end of the battery.
    FixBot'a Sor
    Yorum Ekle
  6. Creative Ziio 7" LCD Screen Replacement: adım 6, 1 resimden 1.
    • There are three additional 3mm Philips #00 screws underneath the circuit board that need to be removed.
    • Now, remove the battery and circuit board with the LCD attached and turn it over so the screen is facing upwards.
    FixBot'a Sor
    Yorum Ekle
  7. Creative Ziio 7" LCD Screen Replacement: adım 7, 2 resimden 1. Creative Ziio 7" LCD Screen Replacement: adım 7, 2 resimden 2.
    • Carefully pry the thin, metal frame from around the LCD screen.
    • The frame is extremely thin! Take your time when removing it to avoid bending or deforming it.
    FixBot'a Sor
    Yorum Ekle
  8. Creative Ziio 7" LCD Screen Replacement: adım 8, 1 resimden 1.
    • Carefully remove the black LCD screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kyle
126 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-10, Maness Spring 2013 Cal Poly, Team 14-10, Maness Spring 2013 üyesi
CPSU-MANESS-S13S14G10
4 Üyeler
15 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where can I buy Creative Ziio 7" LCD Scren?
CoolBlazer - Yanıt Paylaş
i need LCD Creative Labs ZIIO 7 Inch Tablet, where i can buy?... please help me... thx before...
irawansandra - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 38
Her zaman: 1,764
