Ana içeriğe geç
Creative Ziio 7" LCD Screen Replacement
Neye ihtiyacın var
  1. Creative Ziio 7" LCD Screen Replacement, Back Panel: adım 1, 3 resimden 1. Creative Ziio 7" LCD Screen Replacement, Back Panel: adım 1, 3 resimden 2. Creative Ziio 7" LCD Screen Replacement, Back Panel: adım 1, 3 resimden 3.
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
  2. Creative Ziio 7" LCD Screen Replacement, LCD Screen: adım 2, 1 resimden 1.
    • Remove the four 3mm Philips #00 screws around the large silver battery.
  3. Creative Ziio 7" LCD Screen Replacement: adım 3, 1 resimden 1.
    • Remove the four 4mm Philips #00 screws on the edges of the circuit board.
  4. Creative Ziio 7" LCD Screen Replacement: adım 4, 3 resimden 1. Creative Ziio 7" LCD Screen Replacement: adım 4, 3 resimden 2. Creative Ziio 7" LCD Screen Replacement: adım 4, 3 resimden 3.
    • Remove the ribbon cable from the exposed side of circuit board near the headphone jack.
    • Carefully lift up the circuit board on the detached side.
    • There is another ribbon cable attached to the underside of the circuit board.
    • Disconnect the second ribbon cable by pulling the end of the ribbon from its housing on the circuit board with tweezers.
    • The circuit board is extremely delicate. Move carefully and don't rush on this step!
  5. Creative Ziio 7" LCD Screen Replacement: adım 5, 1 resimden 1.
    • On the opposite end of the device: Remove the ribbon cable in between the speakers at the end of the battery.
  6. Creative Ziio 7" LCD Screen Replacement: adım 6, 1 resimden 1.
    • There are three additional 3mm Philips #00 screws underneath the circuit board that need to be removed.
    • Now, remove the battery and circuit board with the LCD attached and turn it over so the screen is facing upwards.
  7. Creative Ziio 7" LCD Screen Replacement: adım 7, 2 resimden 1. Creative Ziio 7" LCD Screen Replacement: adım 7, 2 resimden 2.
    • Carefully pry the thin, metal frame from around the LCD screen.
    • The frame is extremely thin! Take your time when removing it to avoid bending or deforming it.
  8. Creative Ziio 7" LCD Screen Replacement: adım 8, 1 resimden 1.
    • Carefully remove the black LCD screen.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kyle
120 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-10, Maness Spring 2013 Cal Poly, Team 14-10, Maness Spring 2013 üyesi
CPSU-MANESS-S13S14G10
4 Üyeler
13 adet Kılavuz yazıldı
2 Yorum
Where can I buy Creative Ziio 7" LCD Scren?
CoolBlazer - Yanıt
i need LCD Creative Labs ZIIO 7 Inch Tablet, where i can buy?... please help me... thx before...
irawansandra -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 1,367
