Ana içeriğe geç
Creative Ziio 7" Left Speaker Replacement
Neye ihtiyacın var
  1. Creative Ziio 7" Left Speaker Replacement, Back Panel: adım 1, 3 resimden 1. Creative Ziio 7" Left Speaker Replacement, Back Panel: adım 1, 3 resimden 2. Creative Ziio 7" Left Speaker Replacement, Back Panel: adım 1, 3 resimden 3.
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
  2. Creative Ziio 7" Left Speaker Replacement, Left Speaker: adım 2, 1 resimden 1.
    • The left speaker is directly below the battery and on the side with the main red and black wires.
    • Unscrew the two 4mm Philips #00 screws using a Philips Screwdriver.
  3. Creative Ziio 7" Left Speaker Replacement: adım 3, 2 resimden 1. Creative Ziio 7" Left Speaker Replacement: adım 3, 2 resimden 2.
    • Once the screws are removed, discard the broken speaker.
    • Replace the broken speaker with new left speaker.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kyle
120 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-10, Maness Spring 2013 Cal Poly, Team 14-10, Maness Spring 2013 üyesi
CPSU-MANESS-S13S14G10
4 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 11
Her zaman: 333
