Ana içeriğe geç
Creative Ziio 7" Motherboard Replacement
Neye ihtiyacın var
  1. Creative Ziio 7" Motherboard Replacement, Back Panel: adım 1, 3 resimden 1. Creative Ziio 7" Motherboard Replacement, Back Panel: adım 1, 3 resimden 2. Creative Ziio 7" Motherboard Replacement, Back Panel: adım 1, 3 resimden 3.
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
    FixBot'a Sor
    Yorum Ekle
  2. Creative Ziio 7" Motherboard Replacement, Motherboard: adım 2, 3 resimden 1. Creative Ziio 7" Motherboard Replacement, Motherboard: adım 2, 3 resimden 2. Creative Ziio 7" Motherboard Replacement, Motherboard: adım 2, 3 resimden 3.
    • Remove the copper plate covering the motherboard by desoldering the ten solder points.
    • The solder point in the bottom right corner is marked but hidden by the soldering iron.
    FixBot'a Sor
    Yorum Ekle
  3. Creative Ziio 7" Motherboard Replacement: adım 3, 2 resimden 1. Creative Ziio 7" Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the adhesive tape covering the three wires connected to the motherboard.
    • Desolder the solder points connecting the wires to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  4. Creative Ziio 7" Motherboard Replacement: adım 4, 3 resimden 1. Creative Ziio 7" Motherboard Replacement: adım 4, 3 resimden 2. Creative Ziio 7" Motherboard Replacement: adım 4, 3 resimden 3.
    • Disconnect the ribbon cable that is attached underneath the copper plate.
    • Disconnect the other ribbon cable that is connected next the copper plate in the corner of the circuit board.
    FixBot'a Sor
    Yorum Ekle
  5. Creative Ziio 7" Motherboard Replacement: adım 5, 2 resimden 1. Creative Ziio 7" Motherboard Replacement: adım 5, 2 resimden 2.
    • Remove the four 4mm Philips #00 screws holding the motherboard to the casing.
    • The copper plate will be removed by now. However, the picture does not show this.
    FixBot'a Sor
    Yorum Ekle
  6. Creative Ziio 7" Motherboard Replacement: adım 6, 2 resimden 1. Creative Ziio 7" Motherboard Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Lift up the motherboard.
    • A mesh-looking strip on the left side will be connected to the bottom of the motherboard.
    • Remove the tape on top of the strip and use tweezers or pliers to pull on the strip to unplug it.
    FixBot'a Sor
    Yorum Ekle
  7. Creative Ziio 7" Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the red and black wires with a soldering iron that are located underneath the motherboard.
    • Do not cut or damage the wires in the process. They will be needed for the new motherboard.
    FixBot'a Sor
    Yorum Ekle
  8. Creative Ziio 7" Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove the old motherboard and dispose of it resposibly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Benedict Samoy
34 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-10, Maness Spring 2013 Cal Poly, Team 14-10, Maness Spring 2013 üyesi
CPSU-MANESS-S13S14G10
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 1,442
