Giriş
If you need to replace the front door of the Cricut, use this guide to access and remove it. If the front door gets severely cracked or becomes misaligned, it may need to be replaced. For this repair, you need a Phillips #2 and #1 screwdrivers. No steps are particularly difficult, but there are a good number of them, and they require careful attention as to not crack or break any parts.
Neye ihtiyacın var
On both the left and right sides of the Cricut, locate the two internal screws.
Use a Phillips #1 screwdriver bit to unscrew the top 10.8 mm screw and the lower 9.1 mm screw on each side, four screws in total.
