Ana içeriğe geç
Cricut Explore Air 2 Roller Bar Motor Replacement
Neye ihtiyacın var
  1. Cricut Explore Air 2 Roller Bar Motor Replacement, Roller Bar Motor: adım 1, 2 resimden 1. Cricut Explore Air 2 Roller Bar Motor Replacement, Roller Bar Motor: adım 1, 2 resimden 2.
    • With the Cricut open, access the two internal screws on the front left side.
    • Use the Phillips #1 screwdriver to remove the top 10.82 mm screw and the bottom 9.1 mm screw.
  2. Cricut Explore Air 2 Roller Bar Motor Replacement: adım 2, 2 resimden 1. Cricut Explore Air 2 Roller Bar Motor Replacement: adım 2, 2 resimden 2.
    • Rotate the Cricut so the bottom is facing upwards.
    • Identify the two screws with pads.
    • Using the Phillips #2 screwdriver, remove both 42.77 mm screws.
  3. Cricut Explore Air 2 Roller Bar Motor Replacement: adım 3, 1 resimden 1.
    • Rotate the Cricut back to its upright position.
    • Gently lift the cover on the left side of the machine to reveal the parts underneath.
  4. Cricut Explore Air 2 Roller Bar Motor Replacement: adım 4, 2 resimden 1. Cricut Explore Air 2 Roller Bar Motor Replacement: adım 4, 2 resimden 2.
    • Locate the circuit board on the cover just removed.
    • Use the Phillips #1 screwdriver to unscrew each of the four 10 mm screws.
  5. Cricut Explore Air 2 Roller Bar Motor Replacement: adım 5, 1 resimden 1.
    • Gently unplug the connector, removing the circuit board.
  6. Cricut Explore Air 2 Roller Bar Motor Replacement: adım 6, 1 resimden 1.
    • Gently unplug the connector located on the roller bar motor.
  7. Cricut Explore Air 2 Roller Bar Motor Replacement: adım 7, 1 resimden 1.
    • Locate the three screws securing the plate holding the roller bar motor to the Cricut.
    • Use the Phillips #1 screwdriver to remove each of the three 5 mm screws.
  8. Cricut Explore Air 2 Roller Bar Motor Replacement: adım 8, 1 resimden 1.
    • Remove the motor from the interior of the Cricut.
  9. Cricut Explore Air 2 Roller Bar Motor Replacement: adım 9, 1 resimden 1.
    • Gently remove the white gear from the roller bar motor.
  10. Cricut Explore Air 2 Roller Bar Motor Replacement: adım 10, 1 resimden 1.
    • Locate the two screws holding the roller bar motor to the mounting plate.
    • Use the Phillips #1 screwdriver to remove the two 2 mm screws.
  11. Cricut Explore Air 2 Roller Bar Motor Replacement: adım 11, 1 resimden 1.
    • Remove the motor from the plate.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 64
