Ana içeriğe geç
Cricut Maker Front Door Replacement
Neye ihtiyacın var
  1. Cricut Maker Front Door Replacement, Cricut Maker Lid Replacement: adım 1, 3 resimden 1. Cricut Maker Front Door Replacement, Cricut Maker Lid Replacement: adım 1, 3 resimden 2. Cricut Maker Front Door Replacement, Cricut Maker Lid Replacement: adım 1, 3 resimden 3.
    • To remove the cover from the connecting joint, use an iFixit opening tool, and pry around the perimeter of the cover to release it.
    • Applying too much pressure to this can break it as it is very fragile.
    • There is some adhesive holding the cover, so it may take some patience and finesse to pry the cover off.
    • Remove the cover from the connecting joint and set it aside.
  2. Cricut Maker Front Door Replacement: adım 2, 2 resimden 1. Cricut Maker Front Door Replacement: adım 2, 2 resimden 2.
    • Remove the four, 10 mm Torx TR8 security screws holding the lid in place.
  3. Cricut Maker Front Door Replacement: adım 3, 3 resimden 1. Cricut Maker Front Door Replacement: adım 3, 3 resimden 2. Cricut Maker Front Door Replacement: adım 3, 3 resimden 3.
    • Turn the device around, so that the back is facing you.
    • Look for the small rectangles along the back of the device. For every two rectangles, there is one cylindrical connector in between the two.
    • Wedge one or two iFixit opening picks in the seam connecting the Top Door to the device, and use the iFixit opening tool to pry upwards along the seam.
    • These actions should reveal the cylindrical connectors.
  4. Cricut Maker Front Door Replacement: adım 4, 1 resimden 1.
    • Press down on the lid.
    • Push the lid outwards to free it from the jointed clasps.
  5. Cricut Maker Front Door Replacement, Front Door Replacement: adım 5, 2 resimden 1. Cricut Maker Front Door Replacement, Front Door Replacement: adım 5, 2 resimden 2.
    • Using your hands or an opening tool, remove the four foot pads covering four screws.
    • Use a Phillips #1 screwdriver to remove four 41 mm screws from the feet.
  6. Cricut Maker Front Door Replacement: adım 6, 3 resimden 1. Cricut Maker Front Door Replacement: adım 6, 3 resimden 2. Cricut Maker Front Door Replacement: adım 6, 3 resimden 3.
    • Remove the seven screws (Four 8.5 mm screws, and three 12.5 mm screws) on the bottom of the device, this will allow you to remove the cover later on.
    • Use a Phillips #1 screwdriver to remove the four 8.5 mm screws from the bottom of the device.
    • Use a Phillips #0 screwdriver to remove the three 12.5 mm screws.
  7. Cricut Maker Front Door Replacement: adım 7, 3 resimden 1. Cricut Maker Front Door Replacement: adım 7, 3 resimden 2. Cricut Maker Front Door Replacement: adım 7, 3 resimden 3.
    • Turn the device on its side.
    • To remove the seven 10 mm screws from the underside of the top of the device, use a Phillips #1 screwdriver with the flex extension.
  8. Cricut Maker Front Door Replacement: adım 8, 3 resimden 1. Cricut Maker Front Door Replacement: adım 8, 3 resimden 2. Cricut Maker Front Door Replacement: adım 8, 3 resimden 3.
    • Lift the top case off of the base of the device.
    • After removing this cover, the internals of the device will be exposed.
  9. Cricut Maker Front Door Replacement: adım 9, 2 resimden 1. Cricut Maker Front Door Replacement: adım 9, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove four 10 mm screws on the side of the device next to the motors.
    • Use a Phillips #1 screwdriver to remove the two 22 mm screws.
  10. Cricut Maker Front Door Replacement: adım 10, 3 resimden 1. Cricut Maker Front Door Replacement: adım 10, 3 resimden 2. Cricut Maker Front Door Replacement: adım 10, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove two 10 mm screws. These are parallel to one another, one on either side of the machine.
    • Use a Phillips #1 screwdriver to remove two 8mm screws, these are also directly parallel to one another on either side of the machine.
  11. Cricut Maker Front Door Replacement: adım 11, 2 resimden 1. Cricut Maker Front Door Replacement: adım 11, 2 resimden 2.
    • Unplug the bundled connector from the motor on both sides of the machine. To to avoid damage, coax the connector out of the socket gently using a spudger.
  12. Cricut Maker Front Door Replacement: adım 12, 2 resimden 1. Cricut Maker Front Door Replacement: adım 12, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove one 10 mm screw from both sides of the machine. This will release wires that are screwed into the sides of device.
    • Once the screws are removed and wires detached, the main body can be lifted off the base, and set aside.
  13. Cricut Maker Front Door Replacement: adım 13, 3 resimden 1. Cricut Maker Front Door Replacement: adım 13, 3 resimden 2. Cricut Maker Front Door Replacement: adım 13, 3 resimden 3.
    • Remove a total of seven 10 mm screws from the underside of the door.
    • One side of the base has two 10mm screws.
    • The other side of the base has five 10 mm screws.
  14. Cricut Maker Front Door Replacement: adım 14, 3 resimden 1. Cricut Maker Front Door Replacement: adım 14, 3 resimden 2. Cricut Maker Front Door Replacement: adım 14, 3 resimden 3.
    • Pry the door from hinges using an iFixit opening tool.
    • Lift upwards and towards you, to remove the door from the hinges.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Devyn White
1.041 İtibar
5 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 88
Her zaman: 1,697
