Giriş
The Circut Maker it is powered by two motors. If your device isn't moving at all, and it's still receiving power, then the motors might need to be replaced. The motors are not identical, so be sure to identify which one is faulty before beginning.
Before beginning the repair, be sure to turn off the device and unplug it from the outlet.
Neye ihtiyacın var
To remove the cover from the connecting joint, use an iFixit opening tool, and pry around the perimeter of the cover to release it.
Remove the cover from the connecting joint and set it aside.
Using your hands or an opening tool, remove the four foot pads covering four screws.
Use a Phillips #1 screwdriver to remove four 41 mm screws from the feet.
Remove the seven screws (Four 8.5 mm screws, and three 12.5 mm screws) on the bottom of the device, this will allow you to remove the cover later on.
Use a Phillips #1 screwdriver to remove the four 8.5 mm screws from the bottom of the device.
Use a Phillips #0 screwdriver to remove the three 12.5 mm screws.
Use a Phillips #1 screwdriver to remove the four 5 mm screws that attach the motor on the left side of the machine.
Bir başkası bu kılavuzu tamamladı.
