Ana içeriğe geç
Cricut Maker Top Door/ Lid Replacement
Neye ihtiyacın var
  1. Cricut Maker Top Door/ Lid Replacement, Cricut Maker Lid Replacement: adım 1, 3 resimden 1. Cricut Maker Top Door/ Lid Replacement, Cricut Maker Lid Replacement: adım 1, 3 resimden 2. Cricut Maker Top Door/ Lid Replacement, Cricut Maker Lid Replacement: adım 1, 3 resimden 3.
    • To remove the cover from the connecting joint, use an iFixit opening tool, and pry around the perimeter of the cover to release it.
    • Applying too much pressure to this can break it as it is very fragile.
    • There is some adhesive holding the cover, so it may take some patience and finesse to pry the cover off.
    • Remove the cover from the connecting joint and set it aside.
  2. Cricut Maker Top Door/ Lid Replacement: adım 2, 2 resimden 1. Cricut Maker Top Door/ Lid Replacement: adım 2, 2 resimden 2.
    • Remove the four, 10 mm Torx TR8 security screws holding the lid in place.
  3. Cricut Maker Top Door/ Lid Replacement: adım 3, 3 resimden 1. Cricut Maker Top Door/ Lid Replacement: adım 3, 3 resimden 2. Cricut Maker Top Door/ Lid Replacement: adım 3, 3 resimden 3.
    • Turn the device around, so that the back is facing you.
    • Look for the small rectangles along the back of the device. For every two rectangles, there is one cylindrical connector in between the two.
    • Wedge one or two iFixit opening picks in the seam connecting the Top Door to the device, and use the iFixit opening tool to pry upwards along the seam.
    • These actions should reveal the cylindrical connectors.
  4. Cricut Maker Top Door/ Lid Replacement: adım 4, 1 resimden 1.
    • Press down on the lid.
    • Push the lid outwards to free it from the jointed clasps.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Devyn White
1.041 İtibar
5 adet Kılavuz yazıldı
Ekip
Bir Yorum
Where i can buy Cricut Maker Top Door/ Lid Replacement?
Maria Ventura - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 18
Son 30 gün: 140
Her zaman: 1,864
