Ana içeriğe geç
Crock-Pot Express Crock Multi-Cooker Heating Element Replacement
Neye ihtiyacın var
  1. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Power Cord: adım 1, 1 resimden 1.
    • Remove the power cord from the wall outlet first, disconnecting power from the device.
  2. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: adım 2, 1 resimden 1.
    • Orient the device with with the LED facing away from the user allowing access to the input jack of the power cord.
  3. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: adım 3, 2 resimden 1. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: adım 3, 2 resimden 2.
    • Grasp the power cord input connector firmly with forefinger and thumb.
    • Without tugging, apply pulling force until the connector is free from device
  4. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Lid: adım 4, 3 resimden 1. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Lid: adım 4, 3 resimden 2. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Lid: adım 4, 3 resimden 3.
    • Orient the crock pot where the lid locked and unlocked icons are visible.
    • Grasp the handle firmly and turn the lid clockwise until the arrow and the lid unlocked icon are facing each other.
    • Remove the lid.
  5. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Heating Element: adım 5, 1 resimden 1.
    • Remove the inner pot and set it aside for reassembly.
  6. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: adım 6, 1 resimden 1.
    • Carefully rotate the Crock-Pot so that the bottom is facing upward, allowing access to the electrical panel.
    • Remove the two 12.4 mm screws with a Phillips #2 screwdriver.
  7. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: adım 7, 1 resimden 1.
    • Rotate the electrical panel cover counter clockwise and pull up until the panel comes free.
  8. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: adım 8, 2 resimden 1. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: adım 8, 2 resimden 2.
    • Remove 3 nuts, 3 washers, 3 spacers, and 3 lock washers using an adjustable wrench to free the heating element from the Crock-Pot housing.
  9. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: adım 9, 1 resimden 1.
    • Remove the 10mm screw and metal plate beneath the electrical nodes using a Phillips #2 screwdriver.
  10. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: adım 10, 1 resimden 1.
    • Remove the 2 red wires from the terminal post by unscrewing the 10mm screw using a Phillips #2 screwdriver and label terminal post as red.
    • Remove 1 white wire from terminal post by unscrewing the 10mm screw using a Phillips #2 screwdriver and label terminal post as white.
  11. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: adım 11, 1 resimden 1.
    • Reorient the crockpot on its side to prepare for the heating element removal.
  12. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: adım 12, 1 resimden 1.
    • Carefully pull the heating element out and rotate it until bottom side is facing up out of the pot.
  13. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: adım 13, 2 resimden 1. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: adım 13, 2 resimden 2.
    • Remove both 19mm screws from the cutout switch housing using a Phillips #2 screwdriver, freeing the heating element from the device.
    • Carefully remove the heating element from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
where do you get a heating element?
Stephanie Brown - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 30
Her zaman: 4,633
