Ana içeriğe geç
Crosley CR42 Bushings Replacement
Neye ihtiyacın var
  1. Crosley CR42 Bushings Replacement, Bushings: adım 1, 2 resimden 1. Crosley CR42 Bushings Replacement, Bushings: adım 1, 2 resimden 2.
    • Turn the device around so the line out port faces you.
    • Remove the ten 12 mm screws with the Phillips screwdriver.
  2. Crosley CR42 Bushings Replacement: adım 2, 3 resimden 1. Crosley CR42 Bushings Replacement: adım 2, 3 resimden 2. Crosley CR42 Bushings Replacement: adım 2, 3 resimden 3.
    • Pull the line out port toward you so you can view the inside of the Crosley.
    • Locate the wires that connect the line out port to the inside of the device.
  3. Crosley CR42 Bushings Replacement: adım 3, 3 resimden 1. Crosley CR42 Bushings Replacement: adım 3, 3 resimden 2. Crosley CR42 Bushings Replacement: adım 3, 3 resimden 3.
    • Pull on the two connections to remove them from the back of the line out port.
    • Remove the antenna wire from the line out port, then remove the line out port and set it aside.
  4. Crosley CR42 Bushings Replacement: adım 4, 2 resimden 1. Crosley CR42 Bushings Replacement: adım 4, 2 resimden 2.
    • Remove the red and black connection underneath the turntable.
  5. Crosley CR42 Bushings Replacement: adım 5, 1 resimden 1.
    • Position yourself in front of the turntable to unscrew the three bushing bolts.
  6. Crosley CR42 Bushings Replacement: adım 6, 3 resimden 1. Crosley CR42 Bushings Replacement: adım 6, 3 resimden 2. Crosley CR42 Bushings Replacement: adım 6, 3 resimden 3.
    • Unscrew the three bushing bolts with the Phillips screw driver.
  7. Crosley CR42 Bushings Replacement: adım 7, 2 resimden 1. Crosley CR42 Bushings Replacement: adım 7, 2 resimden 2.
    • Pull the turntable out from the casing.
    • Remove the three bushing bolts.
  8. Crosley CR42 Bushings Replacement: adım 8, 3 resimden 1. Crosley CR42 Bushings Replacement: adım 8, 3 resimden 2. Crosley CR42 Bushings Replacement: adım 8, 3 resimden 3.
    • Pinch the rubber bushing at the bottom, then pull downwards to remove it.
    • Repeat the previous step for the other two bushings.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Roberto Rosila
328 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-38, Maness Winter 2014 Cal Poly, Team 1-38, Maness Winter 2014 üyesi
CPSU-MANESS-W14S1G38
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 3,144
