Ana içeriğe geç
Crosley CR8005A Belt Replacement
Neye ihtiyacın var
  1. Crosley CR8005A Belt Replacement, Belt: adım 1, 1 resimden 1.
    • Remove the slipmat and locate the small, round clip which holds the turntable platter to the turntable.
    • Insert the iFixit opening tool between the spindle and the clip and pry off the clip.
    • The clip does not need to be replaced and might already be missing.
  2. Crosley CR8005A Belt Replacement: adım 2, 1 resimden 1.
    • After removing the clip, lift the turntable platter off the chrome spindle on the turntable base. The band connects the platter to the turntable base and will likely fall off in this process.
    • There will be some lubricant on the band and the metal prong on the turntable base. Leave this lubricant as is.
  3. Crosley CR8005A Belt Replacement: adım 3, 1 resimden 1.
    • Turn the platter over so that you are looking at the underside.
    • Stretch the new band around the raised, internal circle and loop the band over the raised prong. This will create a teardrop shape with your new band.
    • Try not to over-stretch the new band or you will need to replace it too.
  4. Crosley CR8005A Belt Replacement: adım 4, 1 resimden 1.
    • Turn the platter back over and place it on the spindle.
    • Spin the platter 2 times clockwise to unloop the band from the raised prong on the platter and to loop it around the raised prong on the turntable base. This allows the circular motion of the motor to spin the band and the turntable platter.
    • You may replace the round clip at this point though it is not important to the sound quality of the turntable.
Sonuç
Now, spin some tunes and enjoy your improved sound!
4 farklı kişi bu kılavuzu tamamladı.
Ramie Bell
249 İtibar
1 Kılavuz yazıldı
2 Yorum
what to do if you cannot lift up the platter in step 2.
Priyanka Baghaie - Yanıt
And where is the raised prong in step 3? Can you add an image or close-up?
Herman Sutter - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 66
Her zaman: 13,933
