Ana içeriğe geç
Crown Range Hood AFG-AC/SS Light Bulb Replacement
Neye ihtiyacın var
  1. Crown Range Hood AFG-AC/SS Light Bulb Replacement, Light Bulb: adım 1, 1 resimden 1.
    • Check to make sure the the range hood is off.
    • To turn the range hood off, press the highlighted button.
    • The range hood should not emit any light or make any noise.
  2. Crown Range Hood AFG-AC/SS Light Bulb Replacement: adım 2, 2 resimden 1. Crown Range Hood AFG-AC/SS Light Bulb Replacement: adım 2, 2 resimden 2.
    • Use the Phillips #00 to remove the single screw securing the lightbulb panel to the ceiling of the range.
    • Too prevent both of the items from falling, hold onto the screw and panel during removal.
  3. Crown Range Hood AFG-AC/SS Light Bulb Replacement: adım 3, 1 resimden 1.
    • Slide the lightbulb cover out from the recessed area under the hood.
  4. Crown Range Hood AFG-AC/SS Light Bulb Replacement: adım 4, 2 resimden 1. Crown Range Hood AFG-AC/SS Light Bulb Replacement: adım 4, 2 resimden 2.
    • Twist the light bulb left to remove it from the range hood.
  5. Crown Range Hood AFG-AC/SS Light Bulb Replacement: adım 5, 1 resimden 1.
    • Use a cloth or a paper towel to clean the inside of the light bulb area.
    • Be sure to remove any debris or rust that might impair the installation of the new light bulb.
  6. Crown Range Hood AFG-AC/SS Light Bulb Replacement: adım 6, 1 resimden 1.
    • Guide the new lightbulb to the middle of the lightbulb base.
    • Install the new lightbulb with a twisting motion to the right.
    • Ensure the lightbulb is tightly secured onto the lightbulb base but don't overtighten.
  7. Crown Range Hood AFG-AC/SS Light Bulb Replacement: adım 7, 2 resimden 1. Crown Range Hood AFG-AC/SS Light Bulb Replacement: adım 7, 2 resimden 2.
    • Place the screw back into the light bulb cover.
  8. Crown Range Hood AFG-AC/SS Light Bulb Replacement: adım 8, 1 resimden 1.
    • Set the light bulb cover back onto the light recess.
    • Use the Philips #00 screwdriver to tighten the single screw that holds the light bulb cover in place.
  9. Crown Range Hood AFG-AC/SS Light Bulb Replacement: adım 9, 1 resimden 1.
    • Turn the light on to make sure your repair was successful!
Bitiş Çizgisi
Ken Cantago
169 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 50
Her zaman: 732
