Ana içeriğe geç
Cuisinart CHW-12 Power Cord Replacement
Neye ihtiyacın var
  1. Cuisinart CHW-12 Power Cord Replacement, Power Cord: adım 1, 2 resimden 1. Cuisinart CHW-12 Power Cord Replacement, Power Cord: adım 1, 2 resimden 2.
    • Unplug the coffee-maker from the power source.
    • Use a Phillips head screwdriver to remove the four 7mm screws from the back and the three 8mm screws from the bottom. This will release the bottom cover.
  2. Cuisinart CHW-12 Power Cord Replacement: adım 2, 2 resimden 1. Cuisinart CHW-12 Power Cord Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to remove the two rubber feet marked within the provided pictures.
    • Remove both 8mm Phillips head screws found within the holes where the feet were just removed.
  3. Cuisinart CHW-12 Power Cord Replacement: adım 3, 3 resimden 1. Cuisinart CHW-12 Power Cord Replacement: adım 3, 3 resimden 2. Cuisinart CHW-12 Power Cord Replacement: adım 3, 3 resimden 3.
    • Carefully pull the cover off the bottom of the coffee maker. This will give you access to the inside of the coffee maker.
    • Pull the gray ribbon cable strait out of the black containment box.
  4. Cuisinart CHW-12 Power Cord Replacement: adım 4, 3 resimden 1. Cuisinart CHW-12 Power Cord Replacement: adım 4, 3 resimden 2. Cuisinart CHW-12 Power Cord Replacement: adım 4, 3 resimden 3.
    • Locate the Phillips head screws holding the highlighted plastic shield in place.
    • Remove the two 14mm screws with a Phillips head screwdriver.
    • Carefully slide the shield out of place along the power cord and set it aside.
  5. Cuisinart CHW-12 Power Cord Replacement: adım 5, 3 resimden 1. Cuisinart CHW-12 Power Cord Replacement: adım 5, 3 resimden 2. Cuisinart CHW-12 Power Cord Replacement: adım 5, 3 resimden 3.
    • Remove the two 14mm Phillips head screws securing the plastic containment box.
    • Pull the plastic containment box straight out of the coffee maker.
  6. Cuisinart CHW-12 Power Cord Replacement: adım 6, 2 resimden 1. Cuisinart CHW-12 Power Cord Replacement: adım 6, 2 resimden 2.
    • Remove the four 11mm Phillips head screws in each corner of the plastic containment box.
    • Pull the top from the plastic housing.
  7. Cuisinart CHW-12 Power Cord Replacement: adım 7, 3 resimden 1. Cuisinart CHW-12 Power Cord Replacement: adım 7, 3 resimden 2. Cuisinart CHW-12 Power Cord Replacement: adım 7, 3 resimden 3.
    • Pull the circuit board out of the containment box.
    • Locate the power cable connection point on the circuit board.
    • Desolder the power cable wires connected to the board.
    • Solder iron can cause burns if used improperly.
    • Replace the power cable with the corresponding wires of the new power cable.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Trevor Aspinall
359 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 36
Her zaman: 1,847
