Ana içeriğe geç
Cuisinart CPB-380 Disassembly
Neye ihtiyacın var
  1. Cuisinart CPB-380 Disassembly, Cuisinart CPB-380 Disassembly: adım 1, 3 resimden 1. Cuisinart CPB-380 Disassembly, Cuisinart CPB-380 Disassembly: adım 1, 3 resimden 2. Cuisinart CPB-380 Disassembly, Cuisinart CPB-380 Disassembly: adım 1, 3 resimden 3.
    • Turn the device upside down.
    • Remove all four rubber feet by prying them out using the metal spudger.
    • Once the rubber feet have been removed, use the Phillips #2 screwdriver to remove all four 13mm screws.
  2. Cuisinart CPB-380 Disassembly: adım 2, 2 resimden 1. Cuisinart CPB-380 Disassembly: adım 2, 2 resimden 2.
    • Remove the base from the body of the blender.
  3. Cuisinart CPB-380 Disassembly: adım 3, 3 resimden 1. Cuisinart CPB-380 Disassembly: adım 3, 3 resimden 2. Cuisinart CPB-380 Disassembly: adım 3, 3 resimden 3.
    • Remove the two 11mm screws securing the power cord using the Phillips #2 screwdriver.
    • Gently move the wire aside so that it is not in the way.
  4. Cuisinart CPB-380 Disassembly: adım 4, 3 resimden 1. Cuisinart CPB-380 Disassembly: adım 4, 3 resimden 2. Cuisinart CPB-380 Disassembly: adım 4, 3 resimden 3.
    • Remove the four 13mm screws that hold the black plastic cover using the Phillips #2 screwdriver.
    • Gently remove the black cover.
    • Underneath, you will see a clear plastic cover that should be removed as well.
  5. Cuisinart CPB-380 Disassembly: adım 5, 2 resimden 1. Cuisinart CPB-380 Disassembly: adım 5, 2 resimden 2.
    • Cut the zip tie that holds the black, blue, red, and yellow wires together.
    • Take care not to cut the wires.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 561
