Ana içeriğe geç
Cuisinart CPB-380 Motor Replacement
Neye ihtiyacın var
  1. Cuisinart CPB-380 Motor Replacement, Cuisinart CPB-380 Disassembly: adım 1, 3 resimden 1. Cuisinart CPB-380 Motor Replacement, Cuisinart CPB-380 Disassembly: adım 1, 3 resimden 2. Cuisinart CPB-380 Motor Replacement, Cuisinart CPB-380 Disassembly: adım 1, 3 resimden 3.
    • Turn the device upside down.
    • Remove all four rubber feet by prying them out using the metal spudger.
    • Once the rubber feet have been removed, use the Phillips #2 screwdriver to remove all four 13mm screws.
  2. Cuisinart CPB-380 Motor Replacement: adım 2, 2 resimden 1. Cuisinart CPB-380 Motor Replacement: adım 2, 2 resimden 2.
    • Remove the base from the body of the blender.
  3. Cuisinart CPB-380 Motor Replacement: adım 3, 3 resimden 1. Cuisinart CPB-380 Motor Replacement: adım 3, 3 resimden 2. Cuisinart CPB-380 Motor Replacement: adım 3, 3 resimden 3.
    • Remove the two 11mm screws securing the power cord using the Phillips #2 screwdriver.
    • Gently move the wire aside so that it is not in the way.
  4. Cuisinart CPB-380 Motor Replacement: adım 4, 3 resimden 1. Cuisinart CPB-380 Motor Replacement: adım 4, 3 resimden 2. Cuisinart CPB-380 Motor Replacement: adım 4, 3 resimden 3.
    • Remove the four 13mm screws that hold the black plastic cover using the Phillips #2 screwdriver.
    • Gently remove the black cover.
    • Underneath, you will see a clear plastic cover that should be removed as well.
  5. Cuisinart CPB-380 Motor Replacement: adım 5, 2 resimden 1. Cuisinart CPB-380 Motor Replacement: adım 5, 2 resimden 2.
    • Cut the zip tie that holds the black, blue, red, and yellow wires together.
    • Take care not to cut the wires.
  6. Cuisinart CPB-380 Motor Replacement, Motor: adım 6, 2 resimden 1. Cuisinart CPB-380 Motor Replacement, Motor: adım 6, 2 resimden 2.
    • Remove the four 13mm screws holding down the frame located at the bottom of the inverted blender using the Phillips #2 screwdriver.
    • Remove frame.
  7. Cuisinart CPB-380 Motor Replacement: adım 7, 2 resimden 1. Cuisinart CPB-380 Motor Replacement: adım 7, 2 resimden 2.
    • Grab the motor by the black gear and the white filter.
    • Unscrew the black gear.
  8. Cuisinart CPB-380 Motor Replacement: adım 8, 3 resimden 1. Cuisinart CPB-380 Motor Replacement: adım 8, 3 resimden 2. Cuisinart CPB-380 Motor Replacement: adım 8, 3 resimden 3.
    • With the metal spudger remove the four rubber stoppers.
    • Remove the four 13mm screws with the Phillips #2 screwdriver.
  9. Cuisinart CPB-380 Motor Replacement: adım 9, 1 resimden 1.
    • Separate the top from the motor.
    • Pinch perpendicular to the flat surface and pull out the blue wire.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
What is the part number and price for Cuisinart CPB-380 Motor?
Paul Hagen - Yanıt
What is the part number and price for Cuisinart CBD-380 motor and price....
Paul Hagen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 48
Her zaman: 3,141
