Ana içeriğe geç
Cuisinart CPT-140BK Circuit Board Replacement
Neye ihtiyacın var
  1. Cuisinart CPT-140BK  Circuit Board Replacement, Circuit Board: adım 1, 1 resimden 1.
    • Unplug the toaster before disassembly.
  2. Cuisinart CPT-140BK  Circuit Board Replacement: adım 2, 2 resimden 1. Cuisinart CPT-140BK  Circuit Board Replacement: adım 2, 2 resimden 2.
    • Turn the toaster upside down.
    • Unscrew all 4mm screws using Phillips #2 screwdriver.
  3. Cuisinart CPT-140BK  Circuit Board Replacement: adım 3, 1 resimden 1.
    • Turn the toaster right side up.
    • Lift up the front cover carefully because the cables can be damaged.
    • Pull out the toaster lever knobs by pulling it away from the toaster before removing the top cover.
  4. Cuisinart CPT-140BK  Circuit Board Replacement: adım 4, 3 resimden 1. Cuisinart CPT-140BK  Circuit Board Replacement: adım 4, 3 resimden 2. Cuisinart CPT-140BK  Circuit Board Replacement: adım 4, 3 resimden 3.
    • Detach the cable that connects the toaster to the circuit board, in both control panels.
  5. Cuisinart CPT-140BK  Circuit Board Replacement: adım 5, 1 resimden 1.
    • Carefully lift up the top cover.
  6. Cuisinart CPT-140BK  Circuit Board Replacement: adım 6, 3 resimden 1. Cuisinart CPT-140BK  Circuit Board Replacement: adım 6, 3 resimden 2. Cuisinart CPT-140BK  Circuit Board Replacement: adım 6, 3 resimden 3.
    • The circuit board is located inside the front cover.
    • Unscrew total of six 4mm screws that attach each circuit board to the top cover, using Phillips #2 screwdriver.
    • Remove and replace the circuit board.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 569
