Ana içeriğe geç
Cuisinart CPT-140BK Top Cover Replacement
Neye ihtiyacın var
  1. Cuisinart CPT-140BK Top Cover Replacement, Top Cover: adım 1, 1 resimden 1.
    • Unplug the toaster before disassembly.
  2. Cuisinart CPT-140BK Top Cover Replacement: adım 2, 2 resimden 1. Cuisinart CPT-140BK Top Cover Replacement: adım 2, 2 resimden 2.
    • Flip the toaster over so the bottom is facing up.
    • Unscrew all 4mm screws in the base using Phillips #2 screwdriver.
  3. Cuisinart CPT-140BK Top Cover Replacement: adım 3, 2 resimden 1. Cuisinart CPT-140BK Top Cover Replacement: adım 3, 2 resimden 2.
    • Take off the lever knobs by pulling it away from the toaster.
    • Disconnect the cables that connects the toaster to the circuit board in both panels.
  4. Cuisinart CPT-140BK Top Cover Replacement: adım 4, 3 resimden 1. Cuisinart CPT-140BK Top Cover Replacement: adım 4, 3 resimden 2. Cuisinart CPT-140BK Top Cover Replacement: adım 4, 3 resimden 3.
    • Place the toaster right side up.
    • Carefully lift up the top cover from the interior of the toaster.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 220
