Ana içeriğe geç
Cuisinart DCC-1100 Drip Spring Replacement
Neye ihtiyacın var
    1. Cuisinart DCC-1100 Drip Spring Replacement, Drip Spring: adım 1, 1 resimden 1.
      • Unplug the coffee maker.
      FixBot'a Sor
      Yorum Ekle
    2. Cuisinart DCC-1100 Drip Spring Replacement: adım 2, 1 resimden 1.
      • Remove the coffee pot and open the top lid.
      FixBot'a Sor
      Yorum Ekle
    3. Cuisinart DCC-1100 Drip Spring Replacement: adım 3, 2 resimden 1. Cuisinart DCC-1100 Drip Spring Replacement: adım 3, 2 resimden 2.
      • Remove the basket filter holder.
      FixBot'a Sor
      Yorum Ekle
    4. Cuisinart DCC-1100 Drip Spring Replacement: adım 4, 1 resimden 1.
      • Remove the basket filter from the holder.
      FixBot'a Sor
      Yorum Ekle
    5. Cuisinart DCC-1100 Drip Spring Replacement: adım 5, 1 resimden 1.
      • Press up on the drip spring mechanism.
      FixBot'a Sor
      Yorum Ekle
    6. Cuisinart DCC-1100 Drip Spring Replacement: adım 6, 2 resimden 1. Cuisinart DCC-1100 Drip Spring Replacement: adım 6, 2 resimden 2.
      • While pressing up on the drip spring mechanism, remove the clear round plastic retainer holding the mechanism in place.
      FixBot'a Sor
      Yorum Ekle
    7. Cuisinart DCC-1100 Drip Spring Replacement: adım 7, 1 resimden 1.
      • Remove the spring from the dripper.
      FixBot'a Sor
      Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Josh Harvey
910 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S20-G4, Passmore Spring 2018 USF Tampa, Team S20-G4, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S20G4
4 Üyeler
27 adet Kılavuz yazıldı
4Kılavuz Yorumları
Where do you find replacement springs?
Mrich - Yanıt Paylaş
I have Cuisinart's Grind & Brew machine and it has an identical drip plug assembly. I measured carefully with a caliper and arrived at this spring size: 12 mm OD, 0.5 mm wire diameter, 30 mm free length. https://www.amazon.com/uxcell-0-5mmx12mm...
Chris Rockett - Yanıt Paylaş
My basket holder has thrown off the clear plastic retainer ring; is there a replacement part I can purchase?
Raymond Classen - Yanıt Paylaş
When the basket holder came apart - the clear plasted retainer ring came off of mine, also. Can you just purchase this piece?
ncrenshaw4 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 79
Her zaman: 13,981
