Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
This guide will help you replace the hot plate of the Cuisinart DCC-1100. Please have a replacement hot plate ready for the installation and unplug the machine before beginning work.
  1. Unplug the coffee maker.
    • Unplug the coffee maker.
  2. Remove the coffee pot and place the coffee maker upside down.
    • Remove the coffee pot and place the coffee maker upside down.
  3. Remove the five 1.6mm Phillips #1 screws from the bottom panel.
    • Remove the five 1.6mm Phillips #1 screws from the bottom panel.
  4. Remove the bottom panel.
    • Remove the bottom panel.
  5. Remove the two 1.6mm Phillips #0 screws from the retaining bracket on the heating element.
    • Remove the two 1.6mm Phillips #0 screws from the retaining bracket on the heating element.
  6. Remove the retaining bracket and allow it to hang off of the heating element.
    • Remove the retaining bracket and allow it to hang off of the heating element.
  7. Remove the hot plate from the heating element.
    • Remove the hot plate from the heating element.
    • New thermal paste should be applied at time of installation.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Josh Harvey
718 İtibar
4 adet Kılavuz yazıldı
Takım
USF Tampa, Team S20-G4, Passmore Spring 2018 USF Tampa, Team S20-G4, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S20G4
4 Üyeler
7 adet Kılavuz yazıldı
4 Yorum
thank you for this informative display.
I have broken many expensive glass carafs for my cuisinart coffeemaker and finally purchased a cuisinart thermal caraf.
I do not need the hotplate to heat, so what do I do to stop the heating process?
I imagine I would need to remove one of the attached lines to the heating element, yes?
Thanks.
Luciano
luciano1213@msn.com
Luciano Muzzatti - Yanıt
Hi, Thanks for sharing this information. I have an older Krups coffee maker that still works great but the hot plate is warn. I cannot seem to find a replacement plate for any Krups coffee maker models. Any suggestions? Thanks!
Paulette Paglia - Yanıt
Josh
where do I buy the replacement hot plate?? I have the sis 15 coffeemaker and I have googled all over the place?? Thank u
linkev428 - Yanıt
Yes, where do you buy the part??
Kathy Johnston - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 35
Son 30 gün: 144
Her zaman: 993
