Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the coffee pot and place the coffee maker upside down.
Remove the five 1.6mm Phillips #1 screws from the bottom panel.
Remove the two 1.6mm Phillips #0 screws from the retaining bracket on the heating element.
Remove the retaining bracket and allow it to hang off of the heating element.
4 farklı kişi bu kılavuzu tamamladı.
13 Yorum
thank you for this informative display.
I have broken many expensive glass carafs for my cuisinart coffeemaker and finally purchased a cuisinart thermal caraf.
I do not need the hotplate to heat, so what do I do to stop the heating process?
I imagine I would need to remove one of the attached lines to the heating element, yes?
Thanks.
Luciano
luciano1213@msn.com
Hi, Thanks for sharing this information. I have an older Krups coffee maker that still works great but the hot plate is warn. I cannot seem to find a replacement plate for any Krups coffee maker models. Any suggestions? Thanks!
Yes, where do you buy the part??
