Ana içeriğe geç
Cuisinart DCC-1100 Power Cord Replacement
Neye ihtiyacın var
  1. Cuisinart DCC-1100 Power Cord Replacement, Power Cord: adım 1, 2 resimden 1. Cuisinart DCC-1100 Power Cord Replacement, Power Cord: adım 1, 2 resimden 2.
    • Unplug the maker, remove the coffee pot, and flip upside down.
  2. Cuisinart DCC-1100 Power Cord Replacement: adım 2, 2 resimden 1. Cuisinart DCC-1100 Power Cord Replacement: adım 2, 2 resimden 2.
    • Remove the five 1.6mm Phillips #1 screws from the bottom panel.
    • Remove the bottom panel.
  3. Cuisinart DCC-1100 Power Cord Replacement: adım 3, 2 resimden 1. Cuisinart DCC-1100 Power Cord Replacement: adım 3, 2 resimden 2.
    • Push the power cord inward and away from the plastic protection plate.
  4. Cuisinart DCC-1100 Power Cord Replacement: adım 4, 2 resimden 1. Cuisinart DCC-1100 Power Cord Replacement: adım 4, 2 resimden 2.
    • Remove the two 1.4mm Phillips #0 screws from the plastic protection plate.
    • Remove the plastic protection plate.
  5. Cuisinart DCC-1100 Power Cord Replacement: adım 5, 3 resimden 1. Cuisinart DCC-1100 Power Cord Replacement: adım 5, 3 resimden 2. Cuisinart DCC-1100 Power Cord Replacement: adım 5, 3 resimden 3.
    • Remove the two 1.6mm Phillips #1 screws from the heating element.
    • Using a flathead screwdriver to remove the outer clips holding the heating unit in place.
    • Flip the heating element up to allow access to the circuit board.
  6. Cuisinart DCC-1100 Power Cord Replacement: adım 6, 2 resimden 1. Cuisinart DCC-1100 Power Cord Replacement: adım 6, 2 resimden 2.
    • Pull out the circuit board and rest it on the side of the machine.
    • Desolder the power cable from the motherboard.
Sonuç
Nicholas Eales
263 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S20-G4, Passmore Spring 2018 USF Tampa, Team S20-G4, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S20G4
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 35
Her zaman: 1,899
