Ana içeriğe geç
Cuisinart DCC-1100 Selection Knob Replacement
Neye ihtiyacın var
  1. Cuisinart DCC-1100 Selection Knob Replacement, Selection Knob: adım 1, 2 resimden 1. Cuisinart DCC-1100 Selection Knob Replacement, Selection Knob: adım 1, 2 resimden 2.
    • Remove the coffee pot.
  2. Cuisinart DCC-1100 Selection Knob Replacement: adım 2, 2 resimden 1. Cuisinart DCC-1100 Selection Knob Replacement: adım 2, 2 resimden 2.
    • Open the lid.
    • Remove the two 1.6mm Phillips #1 screws from the lid.
  3. Cuisinart DCC-1100 Selection Knob Replacement: adım 3, 1 resimden 1.
    • Remove the lid from the coffee maker.
  4. Cuisinart DCC-1100 Selection Knob Replacement: adım 4, 1 resimden 1.
    • Remove the two 1.3mm screws from the display.
  5. Cuisinart DCC-1100 Selection Knob Replacement: adım 5, 2 resimden 1. Cuisinart DCC-1100 Selection Knob Replacement: adım 5, 2 resimden 2.
    • Push the display into the maker so that way you can access the screws in the back.
    • Remove the four 1mm Phillips #0 screws from the back.
  6. Cuisinart DCC-1100 Selection Knob Replacement: adım 6, 2 resimden 1. Cuisinart DCC-1100 Selection Knob Replacement: adım 6, 2 resimden 2.
    • Remove the back panel.
    • Remove the front panel from the display.
  7. Cuisinart DCC-1100 Selection Knob Replacement: adım 7, 1 resimden 1.
    • Remove the three 1mm Phillips #0 screws from the knob.
  8. Cuisinart DCC-1100 Selection Knob Replacement: adım 8, 1 resimden 1.
    • Remove the knob from the front panel.
  9. Cuisinart DCC-1100 Selection Knob Replacement: adım 9, 1 resimden 1.
    • Remove the plastic ring from the knob.
Sonuç
Josh Harvey
889 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S20-G4, Passmore Spring 2018 USF Tampa, Team S20-G4, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S20G4
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 898
