Ana içeriğe geç
Cuisinart DCC-1200 Hose Replacement
Neye ihtiyacın var
    1. Cuisinart DCC-1200  Hose Replacement, Water Hoses: adım 1, 3 resimden 1. Cuisinart DCC-1200  Hose Replacement, Water Hoses: adım 1, 3 resimden 2. Cuisinart DCC-1200  Hose Replacement, Water Hoses: adım 1, 3 resimden 3.
      • Flip the coffee maker over so the bottom is facing upwards.
      • Use the screwdriver with size 4 extension with the T10 Torx bit to remove all four 17 mm long screws.
      • Lift the bottom cover off the bottom of the coffee maker.
      FixBot'a Sor
      Yorum Ekle
    2. Cuisinart DCC-1200  Hose Replacement: adım 2, 2 resimden 1. Cuisinart DCC-1200  Hose Replacement: adım 2, 2 resimden 2.
      • Gently squeeze the hose clamps together and begin moving the metal clamp away from the heating element.
      FixBot'a Sor
      Yorum Ekle
    3. Cuisinart DCC-1200  Hose Replacement: adım 3, 3 resimden 1. Cuisinart DCC-1200  Hose Replacement: adım 3, 3 resimden 2. Cuisinart DCC-1200  Hose Replacement: adım 3, 3 resimden 3.
      • Gently pull on the loose hose to remove it from the heating element.
      FixBot'a Sor
      Yorum Ekle
    4. Cuisinart DCC-1200  Hose Replacement: adım 4, 3 resimden 1. Cuisinart DCC-1200  Hose Replacement: adım 4, 3 resimden 2. Cuisinart DCC-1200  Hose Replacement: adım 4, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Squeeze the clamp with tweezers on the opposite end of the hose from the one you already removed.
      • Once the clamp is free, gently pull upwards on the hose to remove it.
      • Replace the disconnected hose with a new functioning hose.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Austin Wheaton
903 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Stout, Team S8-G1, Ogden Spring 2018 UW Stout, Team S8-G1, Ogden Spring 2018 üyesi
UWSTOUT-OGDEN-S18S8G1
4 Üyeler
20 adet Kılavuz yazıldı
12Kılavuz Yorumları
I think this was a brand new coffee maker used for this demo. My hoses will not budge. I would guess they soften up and permanently adhere to heating element over time. Also, from other videos, there is a ball in the hose (to control direction of water.) Not sure if you can replace with any old hose.
George Heynen - Yanıt Paylaş
Oh yeah that really helped, why not tell us where you got the hose or what type it is?
Silicon Durometer 50 or 70 or is it something else, totally useless site, waste of time.
Ronald Swapp - Yanıt Paylaş
Wish someone would answer this good question…
kenzenmaster - Yanıt Paylaş
Where to get, and what kind of replacement hoses ??? Do you need a new ball in little filter , or do you need the filter at all ???
https://www.amazon.com/gp/product/B003SY... this is where I ordered red hose from. $5.69 for a foot.
Mike carey - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 41
Son 30 gün: 141
Her zaman: 19,330
