Ana içeriğe geç
Cuisinart DCC-1200 Coffee Carafe Handle Replacement
Neye ihtiyacın var
  1. Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: adım 1, 3 resimden 1. Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: adım 1, 3 resimden 2. Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: adım 1, 3 resimden 3.
    • Wedge the metal spudger between the plug and the handle.
    • Carefully pry the plug with the metal spudger by applying pressure around the plug.
    • Too much pressure and prying can damage the plug.
  2. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: adım 2, 2 resimden 1. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: adım 2, 2 resimden 2.
    • Use the bit driver with the Phillips PH1 bit to remove the 27 millimeter long screw in the base of the handle.
  3. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: adım 3, 1 resimden 1.
    • Lift up on and remove the lid from the carafe.
  4. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: adım 4, 2 resimden 1. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: adım 4, 2 resimden 2.
    • Position the metal spudger underneath the top cap of the handle.
    • Gently pry up to extract the upper assembly cap.
    • Pry carefully to prevent from causing aesthetic damage to upper assembly cap.
  5. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: adım 5, 1 resimden 1.
    • Use the bit driver with the Phillips PH1 to remove the 5 millimeter screw in upper assembly of handle.
    • Remove handle by lifting straight up.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Austin Wheaton
861 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Stout, Team S8-G1, Ogden Spring 2018 UW Stout, Team S8-G1, Ogden Spring 2018 üyesi
UWSTOUT-OGDEN-S18S8G1
4 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
I needed this guide after my spouse put the carafe in the dishwasher and the handle sloshed no matter how much I shook it. It turns out water is easily trapped under the top cap; even though there's a drain hole into the handle, it doesn't seem to want to drain. I've wiped it off and left it to dry completely before reassembling it.
Max - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 33
Her zaman: 3,729
