Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Wedge the metal spudger between the plug and the handle.
Carefully pry the plug with the metal spudger by applying pressure around the plug.
Use the bit driver with the Phillips PH1 bit to remove the 27 millimeter long screw in the base of the handle.
Position the metal spudger underneath the top cap of the handle.
Gently pry up to extract the upper assembly cap.
Use the bit driver with the Phillips PH1 to remove the 5 millimeter screw in upper assembly of handle.
Remove handle by lifting straight up.
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I needed this guide after my spouse put the carafe in the dishwasher and the handle sloshed no matter how much I shook it. It turns out water is easily trapped under the top cap; even though there's a drain hole into the handle, it doesn't seem to want to drain. I've wiped it off and left it to dry completely before reassembling it.
